[GeoNetwork-users] Changing node's logo
Dear all,
I' using GN 2.1 and I want to change node's logo. But I can't find the sources.xml (where it should be changed) in \web\xml. Searching the GN installation folder no ducument sources.xml can be found.
Was it renamed in the current version or where it has to be changed?
Best regards
Christian
refert to :
http://www.nabble.com/forum/ViewPost.jtp?post=12980230&framed=y&skin=18419
best regards
Fabien Bachraty
Christian Gadge wrote:
Dear all,
Best regards
Christian
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/Changing-node's-logo-tf4553981s18419.html#a12996466
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Fabien,
I am a geonetwork newbie . I have tried to change my node logo by following
your instruction ( replace the logo file by naming it with SiteID.gif)
because I didn't find file sources.xml. but it's still failed. the logo
didn't display at all. What should I check then? is there any other steps?
thanks before
-nasree
FBachraty wrote:
refert to :
best regards
Fabien Bachraty
Dear all,
Best regards
Christian
View this message in context: http://n2.nabble.com/Changing-node's-logo-tp2013832p2161168.html
