Dear GeoNetwork-Userlist,
I try to adapt the vector template in GN3 according to a specific metadata-profile.
Adding metadata-elements in the xml-structure of the template and the respective values in codelist.xml and label.xml seems to work fine with a locally installed version of GN3.
However these changes are not shown in the version of GN3 that runs on a tomcat apache webserver, even though the adapted xml-files are stored properly in the directories of GN on the webserver.
I would be grateful for any information regarding a possible cause for that issue.
With kind regards,
Silvan Wild
2015-09-12 19:21 GMT+02:00 Silvan Wild <silvanwild@anonymised.com>:
metadata-profile.
that issue.
Maybe check where are the schema plugins located from
http://localhost:8080/geonetwork/srv/eng/admin.console#/dashboard/information
"Standard folder"
to be sure you're editing the correct files.
HTH
Francois
With kind regards,
Silvan Wild
GeoNetwork-users mailing list
