Hi Florent
Thanks a lot for the hints!
Finally I found a fix for my situation, but i think it's quite a dirty
one...
The geoserver character encoding was already set to UTF-8 in global
options. The spanish special characters in the WMS capabilities XML are
shown fine in the browser or when connecting with QGIS. But not in
Geonetwork.
Then I tried to set geoserver character encoding to latin1 like Hoddih
did, but didn't worked for me.
Firebug states that the content-type in geoserver response header is
text/xml - but the charset=utf-8 is missing (there is no charset
information).
The first line of recieved capabilities XML starts with <?xml
version="1.0" encoding="UTF-8">.
So I changed the line 249 in the proxy script you mencioned to
String responseBody =
IOUtils.toString(httpResponse.getEntity().getContent(), "UTF-8").trim();
This works, the special characters in WMS capabilities XML from
geoserver are shown fine in geonetwork now.
But I think proxy-script only works in utf-8 now, so i would appreciate
any help to do this in a better way.
El 15/10/15 a las 02:21, Florent Gravin escribió:
I think you just need to change the output encoding directly into your
geoserver.
http://docs.geoserver.org/latest/en/user/webadmin/server/globalsettings.html
On Thu, Oct 15, 2015 at 9:18 AM, Florent Gravin
<florent.gravin@anonymised.com <mailto:florent.gravin@anonymised.com>>
wrote:
Could there be an issue about your map server ?
Check that your getCapabilities request has
1.
Content-Type:
text/xml;charset=UTF_8
If no info is provided, default is Latin1.
Genetwork proxy does the encoding stuff there
https://github.com/geonetwork/core-geonetwork/blob/develop/core/src/main/java/org/geonetwork/http/proxy/HttpProxyServlet.java#L249
It's not about java or tomcat config, just the proxy thing.
On Thu, Oct 15, 2015 at 12:31 AM, Jan Schorn <js@anonymised.com
<mailto:js@anonymised.com>> wrote:
first of all, thanks a lot for all the interesting discussions
on this
list, to me they are very helpful!
But I have still an issue with character encoding of WMS
capabilities
XML. I can't find any way how to resolve it.
In Geonetwork, when Geonetwork gets the capabilities XML of a WMS
(adding a WMS layer to the map or adding a WMS online resource to
metadata), special spanish characters are not shown correctly.
In other words, characters like ó are not shown when requesting the
capabilities XML like this:
http://mygeoportal.org/geonetwork/proxy?url=http%3A%2F%2Fmygeoportal.com%3A80%2Fgeoserver%2Fservices%2Fows%3FSERVICE%3DWMS%26REQUEST%3DGetCapabilities,
firebug informs for response header: Content-Type
text/xml;charset=ISO-8859-1
But the characters in the XML-File are shown correctly in the
browser
requesting the capabilities XML using an URL like:
http://mygeoportal.org/geoserver/services/ows?SERVICE=WMS&REQUEST=GetCapabilities
- in this case firebug informs for response header: Content-Type
text/xml
I'm running Geonetwork 3.0.2 and Geoserver 2.8 as Tomcat8
servlets with
OpenJDK7 under Debian, using Apache HTTPD server with AJP/1.3
connectors
(workers).
Some details about server configuration:
Debian system locale is "es_EC.UTF-8".
Geonetwork postgresql db is UTF-8.
In Apache httpd server config the line AddDefaultCharset utf-8 is
discommented.
Tomcat8: in /etc/tomcat8/web.xml the build in filter
"setCharacterEncodingFilter" is set to UTF-8 per default, also
discommented.
Java System properties in /etc/default/tomcat8 set to
JAVA_OPTS="-Djava.awt.headless=true -Dfile.encoding=UTF-8" (i
also tried
UTF8),
and in /etc/tomcat8/server.xml both parameters URIEncoding="UTF-8"
useBodyEncodingForURI="true" are added to connectors tag.
The Geoserver character encoding is set to UTF-8 in web interface.
Any idea what is missing or wrong with this configuration?
Why is the server-response header of the capabilities XML charset
ISO-8859-1 and not UTF-8 or nothing when using
http:/…/geonetwork/proxy?url=…
Thanks a lot in advance for any help!
All the best,
Jan
GeoNetwork-users mailing list
<mailto:GeoNetwork-users@lists.sourceforge.net>
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
