[GeoNetwork-users] Child with double partents
I have the case where a child should be associated to two parents. Is it
possible?
I tried but at the end it seems that only one parent can be associate to a
child.
Hints?
Eugenio
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi Eugenio,
You should look into using aggregates (named other resources in the menu)
and using association type
https://github.com/geonetwork/core-geonetwork/blob/master/schemas/iso19139/src/main/plugin/iso19139/loc/eng/codelists.xml#L337
Note that 19115-1 added some values like series (
https://github.com/metadata101/iso19115-3/blob/3.4.x/src/main/plugin/iso19115-3/loc/eng/codelists.xml#L568-L574)
in associtation type.
HTH.
Francois
Le mar. 4 sept. 2018 à 14:54, frippe12573 <frippe12573@anonymised.com> a
écrit :
possible?
child.
Hints?
Eugenio
Sent from:
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
