[GeoNetwork-users] Command-line Batch Import
Is there a way to batch-import from command line (not GN Admin GUI menu) ?
I have tens of thousands of directories each holding hundreds of
ISO19139 formatted files.
I could move all the files in those directories into one directory,
but that would make the number in the directory too large.
So I was thinking one way would be to make a shell script that does
the batch(one directory at a time) import for each directory.
Thanks so much for your help.
Yoshi
Have a look at the following python script, it (optionally recursively) batch uploads MEFs from a directory. If you are uploading xml instead of mef, change line 81 from '*.mef' to '*.xml'
http://code.google.com/p/metageta/source/browse/tools/batchuploadmef.py
Luke
-----Original Message-----
From: Yoshi NA [mailto:tombitake1979@anonymised.com]
Sent: Wednesday, 29 August 2012 6:45 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Command-line Batch Import
I could move all the files in those directories into one directory, but that would make the number in the directory too large.
So I was thinking one way would be to make a shell script that does the batch(one directory at a time) import for each directory.
Yoshi
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and threat landscape has changed and how IT managers can respond. Discussions will include endpoint security, mobile security and the latest in malware threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
Hi Luke,
Thanks. But when I run it with the change on line 81 from '*.mef' to
'*.xml' made, I got error messages.
# python batchuploadxml.py -d /mnt/00 -s http://xxx.xxx.xxx -u admin -p xxx -r
Login successfull!
Uploading /mnt/00/01/iso_A2GL10304051419OD1_PS1A0000000.xml
  File "batchuploadxml.py", line 186, in ?
    main(**kwargs)
  File "batchuploadxml.py", line 84, in main
    uploadmef(mef,handler,proxy,cj)
  File "batchuploadxml.py", line 89, in uploadmef
    formvalues['mefFile']=fo
NameError: global name 'formvalues' is not defined
Are there more changes needed to accommodate this script for ISO19139 files ?
And please let me know what I give 'group' to grant "Public" access
from "Guest".
        formvalues={'insert_mode':'1',
                  'file_type':'mef',
                  'data':'',
                  'template':'n',
                  'title':'',
                  'uuidAction':'overwrite',
                  'styleSheet':'_none_',
                  'group':'2',
                  'category':'_none_'
Thanks a lot for your help,
Yoshi
On Thu, Aug 30, 2012 at 9:03 AM, Pinner, Luke
Luke
Yoshi
e-mail or attachments. Please consider the environment before printing this
email.
It's designed for mefs, not xml as that is all we use. I didn't actually test with xml files.
If you get it to work, let me know and I'll look at incorporating your changes into the script.
Luke
Sent: Thursday, 30 August 2012 12:41 PM
To: Pinner, Luke
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Command-line Batch Import
Hi Luke,
Thanks. But when I run it with the change on line 81 from '*.mef' to '*.xml' made, I got error messages.
# python batchuploadxml.py -d /mnt/00 -s http://xxx.xxx.xxx -u admin -p xxx -r Login successfull!
    main(**kwargs)
And please let me know what I give 'group' to grant "Public" access from "Guest".
                  'file_type':'mef',
                  'data':'',
                  'template':'n',
                  'title':'',
                  'group':'2',
                  'category':'_none_'
Yoshi
On Thu, Aug 30, 2012 at 9:03 AM, Pinner, Luke <Luke.Pinner@anonymised.com> wrote:
y
Luke
Yoshi
respect of information in the e-mail or attachments. Please consider
I've fixed the formvalues error, small bug that crept in when I made the script recursive. It still won't handle xml though.
Luke
To: Pinner, Luke
Hi Luke,
Login successfull!
    main(**kwargs)
from "Guest".
                  'file_type':'mef',
                  'data':'',
                  'template':'n',
                  'title':'',
                  'group':'2',
                  'category':'_none_'
Yoshi
Luke
Yoshi
email.
