[GeoNetwork-users] Command line installation of GeoNetwork
Hi everyone,
I am trying to install a test GeoNetwork installation on a remote FreeBSD
server. The jar installer requires a GUI, but I am having trouble with X11
and cannot get it to work... is there a way of installing the service from
the command line, through a .war distribution for example?
Has anyone tried to install GeoNetwork this way?
My installation is the following:
FreeBSD6.2 server, connection via SSH / SFTP
Apache2.2 host, using the mod_jk connector to Tomcat5.5
Charles
Hi Charles, you should be able to do an install on another server.
And then copy/paste to your FreeBSD server, then :
- set up Tomcat /conf/server.xml
- check the Geoentwork config.xml (db if you are not using mckoi, and IPs).
If you don't change the node name that should work fine I think.
HTH.
Francois
-----Message d'origine-----
De : geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] De la part de
Charles Perring
Envoyé : lundi 26 février 2007 15:22
À : geonetwork-users@lists.sourceforge.net
Objet : [GeoNetwork-users] Command line installation of GeoNetwork
Hi everyone,
Charles
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's
Techsay panel and you'll get the chance to share your opinions on IT &
business topics through brief surveys-and earn cash
GeoNetwork-users mailing list
Actually, there's another clean way:
- you can run a server installation locally and fill out all the required parameters that comply with your remote installation.
- The last install screen offers the option to store the installation script, which you should do :slight_smile:
- Than, you copy the installer to the remote server and also the script (you can edit information in the script if you want in a text editor)
- The last step is to run the installer from the command line: java -jar geonetwork-installer.jar script.xml
This will do the command line installation
Ciao,
Jeroen
HTH.
Francois
Charles Perring
Hi everyone,
Charles
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
opinions on IT & business topics through brief surveys-and earn cash
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
