Hi
I have been trying to compile geonetwork with support for iso19115-3 support and I am getting errors when compiling in the submodule. Not sure why it appears as if it is something within the code base. As other schema submodules are compiling fine and also when I leave out iso19115-3. Here is the output from mvn.
Andrew Rae
[INFO] GeoNetwork schema plugin for Dublin Core standard .. SUCCESS [ 0.138 s]
[INFO] GeoNetwork schema plugin for ISO19139/119 standards SUCCESS [ 0.314 s]
[INFO] GeoNetwork schema plugin for ISO19110 standard ..... SUCCESS [ 0.078 s]
[INFO] GeoNetwork schema plugin for ISO19139.anzlic profile SUCCESS [ 0.036 s]
[INFO] GeoNetwork schema plugin for ISO19115-3 standard ... FAILURE [ 0.029 s]
[INFO] BUILD FAILURE
[INFO] Total time: 2.749 s
[INFO] Finished at: 2018-08-07T15:47:58+12:00
[INFO] Final Memory: 32M/344M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.5.1:compile (default-compile) on project schema-iso19115-3: Compilation failure: Compilation failure:
[ERROR] /home/arae/src/java/geonetwork_3.4.3/core-geonetwork-error/schemas/iso19115-3/src/main/java/org/fao/geonet/schema/iso19115_3/ISO19115_3SchemaPlugin.java:[3,0] error: class, interface, or enum expected
[ERROR] /home/arae/src/java/geonetwork_3.4.3/core-geonetwork-error/schemas/iso19115-3/src/main/java/org/fao/geonet/schema/iso19115_3/ISO19115_3SchemaPlugin.java:[5,0] error: class, interface, or enum expected
[ERROR] /home/arae/src/java/geonetwork_3.4.3/core-geonetwork-error/schemas/iso19115-3/src/main/java/org/fao/geonet/schema/iso19115_3/ISO19115_3SchemaPlugin.java:[13,0] error: class, interface, or enum expected
[ERROR] /home/arae/src/java/geonetwork_3.4.3/core-geonetwork-error/schemas/iso19115-3/src/main/java/org/fao/geonet/schema/iso19115_3/ISO19115_3SchemaPlugin.java:[28,0] error: class, interface, or enum expected
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :schema-iso19115-3
Hi Andrew, this has been fixed you can now use branch 3.4.x of
https://github.com/metadata101/iso19115-3 with branch 3.4.x of GeoNetwork.
Cheers.
Francois
Le mar. 7 août 2018 à 06:20, Andrew Rae <andrew.rae@anonymised.com> a écrit :
Hi
Andrew Rae
0.138 s]
0.314 s]
0.078 s]
0.036 s]
0.029 s]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR]
[ERROR]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
