I'm trying to load a google layer but appears this error. Any idea?
2012-11-20 10:05:00,336 INFO [jeeves.request] - HTML Request (from
10.1.2.5) : /geonetwork/srv/ca/main.home
2012-11-20 10:05:00,336 DEBUG [jeeves.request] - Method : GET
2012-11-20 10:05:00,336 DEBUG [jeeves.request] - Content type : null
2012-11-20 10:05:00,336 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2012-11-20 10:05:00,336 DEBUG [jeeves.request] - Session id is
610DFF89FFF808AB910C58C350095953
2012-11-20 10:05:00,336 DEBUG [jeeves.request] - Session created for client
: 10.1.2.5
2012-11-20 10:05:00,352 INFO [jeeves.service] - Dispatching : main.home
2012-11-20 10:05:00,352 DEBUG [jeeves.service] - -> no input parameters
2012-11-20 10:05:00,352 INFO [jeeves.service] - -> dispatching to output
for : main.home
2012-11-20 10:05:00,430 DEBUG [jeeves.engine] - TransformerFactoryFactory:
de.fzi.dbs.xml.transform.CachingTransformerFactory
2012-11-20 10:05:00,445 DEBUG [jeeves.engine] - TransformerFactoryFactory:
produces transformer implementation net.sf.saxon.IdentityTransformer
2012-11-20 10:05:01,801 INFO [jeeves.service] - -> transforming with
stylesheet : C:\tomcat\webapps\geonetwork\/xsl/main-page.xsl
2012-11-20 10:05:01,801 DEBUG [jeeves.engine] - TransformerFactoryFactory:
2012-11-20 10:05:01,801 ERROR [jeeves.service] - -> exception during
transformation for : main.home
2012-11-20 10:05:01,801 ERROR [jeeves.service] - -> (C) stylesheet :
2012-11-20 10:05:01,801 ERROR [jeeves.service] - -> (C) message :
Failed to compile stylesheet. 1 error detected.
2012-11-20 10:05:01,801 ERROR [jeeves.service] - -> (C) exception :
TransformerConfigurationException
2012-11-20 10:05:01,801 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>Failed to compile stylesheet. 1 error detected.</message>
<class>TransformerConfigurationException</class>
<stack>
<at class="net.sf.saxon.PreparedStylesheet"
file="PreparedStylesheet.java" line="176" method="prepare" />
<at class="net.sf.saxon.TransformerFactoryImpl"
file="TransformerFactoryImpl.java" line="139" method="newTemplates" />
<at class="de.fzi.dbs.xml.transform.CachingTransformerFactory"
file="CachingTransformerFactory.java" line="115" method="newTransformer" />
file="CachingTransformerFactory.java" line="70" method="newTransformer" />
<at class="jeeves.utils.Xml" file="Xml.java" line="285"
method="transform" />
<at class="jeeves.utils.Xml" file="Xml.java" line="247"
<at class="jeeves.utils.Xml" file="Xml.java" line="231"
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="711" method="dispatchOutput" />
file="ServiceManager.java" line="405" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="670" method="dispatch" />
</stack>
<request>
<language>ca</language>
<service>main.home</service>
</request>
<response />
</error>
2012-11-20 10:05:01,801 INFO [jeeves.service] - -> dispatching to error
for : main.home
2012-11-20 10:05:01,817 DEBUG [jeeves.engine] - TransformerFactoryFactory:
2012-11-20 10:05:01,832 INFO [jeeves.service] - -> transforming with
stylesheet : C:\tomcat\webapps\geonetwork\/xsl/error.xsl
2012-11-20 10:05:01,832 DEBUG [jeeves.engine] - TransformerFactoryFactory:
2012-11-20 10:05:02,269 INFO [jeeves.service] - -> end error
2012-11-20 10:05:02,269 INFO [jeeves.service] - -> error ended for :
main.home
Thanks!
Víctor
View this message in context: http://osgeo-org.1560.n6.nabble.com/Conect-google-layers-in-mainmap-tp5016229p5017587.html
