Good Morning/afternoon/night,
I'm doing a final work master's degree about Geonetwork. I modified *
config.xml* in (C:\Archivos de programa\Apache Software
Foundation\Tomcat5.5\webapps\geonetwork\WEB-INF)
In order to try to configured Postgresql conection but I Can’t. Paste de
code:
<resources>
<!-- mckoi standalone -->
<resource enabled="true">
<name>main-db</name>
<provider>jeeves.resources.dbms.DbmsPool</provider>
<config>
<user>BayACrsQ</user>
<password>Qf7Po9T0</password>
<driver>com.mckoi.JDBCDriver</driver>
<url>jdbc:mckoi://localhost:9157/</url>
<poolSize>10</poolSize>
</config>
<activator
class="org.fao.geonet.activators.McKoiActivator"><configFile>WEB-INF/db/db.conf</configFile></activator></resource>
<!-- mysql -->
<resource enabled="false">
<config>
<user>admin</user>
<password>admin</password>
<driver>com.mysql.jdbc.Driver</driver>
<url>jdbc:mysql://$WEBSERVER_HOST/geonetwork</url>
<reconnectTime>3600</reconnectTime>
</config>
</resource>
<!-- oracle -->
<config>
<user>admin</user>
<driver>oracle.jdbc.driver.OracleDriver</driver>
<url>jdbc:oracle:thin:@IP
:1521:fs</url>
</config>
</resource>
<!-- postgresql -->
<config>
<user>postgres</user>
<password>artemisia</password>
<driver>org.postgresql.Driver</driver>
jdbc:postgresql:database
jdbc:postgresql://host/database
jdbc:postgresql://host:port/database
<url>jdbc:postgresql:geonetwork</url>
</config>
</resource>
<!-- sqlserver 2008 -->
<config>
<user>www-data</user>
<password>www-data</password>
<driver>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver>
<url>jdbc:sqlserver://SERVER;database=geonetwork;integratedSecurity=false;</url>
</config>
</resource>
</resources>
I would like to see the shapefiles in Geonetwork, but I don’t know how to
see my database postgis in Geonetwork.
Another problem is to visualice two maps wich are in the main page of
geonetwork. I work in localhost:8080 with geonetwork and localhost:8090
with geoserver. I modified *config-gui.xml *(C:\Archivos de
programa\Apache Software Foundation\Tomcat
5.5\webapps\geonetwork\WEB-INF\config-gui.xml) Paste the code:
<mapSearch options="{projection: 'EPSG:4326', maxExtent: new
OpenLayers.Bounds(-180,-90,180,90), units: 'degrees', restrictedExtent: new
OpenLayers.Bounds(-180,-90,180,90)}">
<layers>
<layer server="http://localhost:8090/geoserver/topp/wms" tocName="USA1"
params="{layers: 'topp:states', transparent: 'true', format: 'image/png'}"
options="{}" />
<layer server="http://localhost:8090/geoserver/wms" tocName="Ortophoto"
params="{layers: 'gn:world', format: 'image/jpeg'}" options="{isBaseLayer:
true}" />
</layers>
</mapSearch>
<!-- Configuration for map viewer
mapViewer/@options: OpenLayers options hash as expected in new
OpenLayers.Map(div, options)
proj/crs: Projections used in mapViewer
code CSR code
default Indicates the default CRS (values: 0, 1)
scales: array with scales to show in scale selector control. Empty
array, uses scales created from map configuration
layers/layer:
server url of the server
tocName layer name in map
params OpenLayers params hash as expected in new
OpenLayers.Layer.WMS(name, url, params, options)
options OpenLayers options hash as expected in new
<mapViewer options="{projection: 'EPSG:4326', maxExtent: new
<layers>
<layer server="http://localhost:8090/geoserver/nurc/wms" tocName="UUS
Image" params="{layers: 'nurc:Img_Sample', transparent: 'true', format:
'image/png'}" options="{}" />
tocName="Ortophoto" params="{layers: 'topp:states', format: 'image/jpeg'}"
options="{isBaseLayer: true}" />
</layers>
<scales values="[7500000, 5000000, 2500000, 1000000, 750000, 500000,
250000, 100000, 75000, 50000, 25000, 10000, 7500, 5000, 2500, 1000]" />
<!--scales values="" /-->
<proj>
<crs code="EPSG:4326" default="1" name="WGS84 (lat/lon)" />
</proj>
<servers>
<server name="NASA JPL OneEarth Web Mapping Server (WMS)" url="
http://wms.jpl.nasa.gov/wms.cgi?" />
<server name="NASA Earth Observations (NEO) WMS" url="
http://neowms.sci.gsfc.nasa.gov/wms/wms?" />
<server name="DEMIS World Map Server" url="
http://www2.demis.nl/mapserver/wms.asp?" />
<server name="Geoserver" url="http://localhost:8090/geoserver/wms?" />
</servers>
</mapViewer>
Any idea to solve both problems.
I’ll appreciate your help.
Víctor
