[GeoNetwork-users] Configuration for protocol OGC CSW 2.0.2: sortBy Parameter
Dear community,
I have encountered a problem while harvesting pycsw 2.3.dev0 node (OGC CSW 2.0.2) in Geonetwork 3.10.3 using Harvesting section in Admin console.
The paginated results from that endpoint is using random order when listing records. This means that the same record appears in multiple page requests. After harvesting process is finished in Geonetwork many records are missing in "ProvidedBy" facet and I can't figure out from the log file why this happens. I assume that I have to configure for SortBy parameter:
for example: SortBy=apiso:Modified:A
Direct GetRecords request specified as "Service URL" with sortBy parameter didn't solve the problem.
[cid:image003.png@anonymised.com]
How can I configure for SortBy parameter? Any other ideas how to handle unsorted paginated results?
Thanks in advance!
Kind regards,
Dejan Deordic
(attachments)
