Used Geonetwork Version 2.10.4-0
Hi Community,
1.Configuration of Default view in System configuration does not work.
Administration = > (SYSTEM CONFIGURATION/METADATA VIEWS)
Which files must be modified to configure the Default view manually?
2. XML.METADATA.INSERT with java works but finally no polygon is displayed.
After resaving the metadata in edit mode in the GUI solves the problem.
I think it is a permission problem.
- I have compared the user id and group id in the database and they are
correct.
- I have compared the metadata before and after resave. No Problems there!
- User is the default admin
What else can I check to solve this problem ?
Olaf
View this message in context: http://osgeo-org.1560.x6.nabble.com/Configuration-of-Default-View-tp5203264.html
