Hi.
I recently tried version 3, very pleased with the new GUI, but I can't
figure out how to set up my postgresql DB.
Until version 2.10, this was done easily via config.xml
I'd really appreciate any help
Leonardo Dobles
Hi.
Leonardo Dobles
First check which type of database is used. Depending on the node (default
node name is srv) check the node configuration file
WEB-INF/config-node/srv.xml. Choose the database type to use.
Then update the WEB-INF/config-db/jdbc.properties file with connection
information.
Cheers.
Francois
PS: Documentation is being updated.
2015-05-01 20:44 GMT+02:00 Leonardo Dobles <hableconleo@anonymised.com>:
Hi.
figure out how to set up my postgresql DB.Until version 2.10, this was done easily via config.xml
Leonardo Dobles
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
