Dear all
I have been looking for documentation on the GeoNetwork Architecture, which detail the interactions therein but withou much success. All i get is the manual, can someone help me please.
Regards
Juliet Gwenzi
ITC
Mailbox Number 389
Hengelosestraat 99
P. O. Box 6
7500 AA Enschede
The Netherlands
Mobile: +31 647 271 542
Land +31 534 803 999
Email: julievimbai@anonymised.com
gwenzi21943@anonymised.com
Becoming like Jesus is a marathon not a sprint
To: geonetwork-users@lists.sourceforge.net
Sent: Thu, 17 December, 2009 10:51:39 AM
Subject: Re: [GeoNetwork-users] configure geonetwork
I'm using jetty.
I tried to edit the file "geonetwork path/bin/jetty.xml" to change the
server information.
In the xml file I changed "localhost" to our host address (see below)
<Set name="host"><SystemProperty name="jetty.host"
default="localhost"/></Set>
<Set name="port"><SystemProperty name="jetty.port" default="8080"/></Set>
but now I can not access Geonetwork at all, neither from the local nor from
a remote computer.
What are the exact server informations that I have to change in the
jetty.xml file?
Thanks for your help,
Karibu
Marc-André Goderre wrote:
What's the server you're using : Jetty or Tomcat??
If you're using jetty, did you change the server information in this file:
Marc
-----Message d'origine-----
De : karibu [mailto:kat_lore@anonymised.com]
Envoyé : 16 décembre 2009 12:00
À : geonetwork-users@lists.sourceforge.net
Objet : Re: [GeoNetwork-users] configure geonetwork
it is possible to access Geonetwork from the local computer.
I just don't understand why it is not working for a remote computer. I set
the configuration setting to exactly the same like I did for the old
Geonetwork version but somehow it seems not to work.
Any more ideas what could be the problem?
Karibu
Mathieu Coudert-3 wrote:
On Wed, Dec 16, 2009 at 5:23 PM, karibu <kat_lore@anonymised.com> wrote:
but I only run one Geonetwork at the time. Do I still have to change the
port number for the new Geonetwork in order to make it accessible for
remote
computers?
If you are running only once at a time, no, you do not have to change the
port.
Are you able to access to your new GeoNetwork installation from your
local
computer?
Mathieu
Karibu
Sarah_S wrote:
> As far as I know two Gns on one port isn`t good.
> best regards
> Sarah
> Von: karibu <kat_lore@anonymised.com>
> An: geonetwork-users@lists.sourceforge.net
> Gesendet: Mittwoch, den 16. Dezember 2009, 16:48:57 Uhr
> Betreff: Re: [GeoNetwork-users] configure geonetwork
> Hi,
> the error that occurs when I try to access Geonetwork from a remote
> computer
> is a connection failure.
> I have not changed the port number, so it should actually work with
the
> old
> settings, or?
> Thanks,
> Karibu
> Sarah_S wrote:
>> Hi,
>> which errors occured?
>> Do you changed ports,..? Which OS are you running?
>> best regards
>> Sarah
>> Gesendet: Mittwoch, den 16. Dezember 2009, 16:14:01 Uhr
>> Betreff: [GeoNetwork-users] configure geonetwork
>> Hi,
>> so far we used to run Geonetwork 2.2, but now we wanted to change to
2.4.
>> I
>> changed the configuration settings to the ones that we used in
Geonetwork
>> 2.2, but somehow I still can not access 2.4 from a remote computer.
Do
I
>> have to deinstall 2.2 first, or am I just missing something obvious?
>> Karibu
>> View this message in context:
>> http://n2.nabble.com/configure-geonetwork-tp4176015p4176015.html
>> Sent from the GeoNetwork users mailing list archive at Nabble.com.
>> This SF.Net email is sponsored by the Verizon Developer Community
>> Take advantage of Verizon's best-in-class app development support
>> A streamlined, 14 day to market process makes app distribution fast
and
>> easy
>> Join now and get one step closer to millions of Verizon customers
>> http://p.sf.net/sfu/verizon-dev2dev
>> _______________________________________________
>> GeoNetwork-users mailing list
>> GeoNetwork-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
>> GeoNetwork OpenSource is maintained at
>> http://sourceforge.net/projects/geonetwork
>> __________________________________________________
>> Do You Yahoo!?
>> Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden
Schutz
>> gegen Massenmails.
>> http://mail.yahoo.com
and
>> easy
> http://n2.nabble.com/configure-geonetwork-tp4176015p4176207.html
and
> easy
> Do You Yahoo!?
Schutz
> gegen Massenmails.
and
> easy
http://n2.nabble.com/configure-geonetwork-tp4176015p4176367.html
A streamlined, 14 day to market process makes app distribution fast and
easy
easy
http://n2.nabble.com/configure-geonetwork-tp4176015p4176651.html
easy
This message has been verified by LastSpam eMail security service
Ce courriel a �t� v�rifi� par le service de s�curit� pour courriels
LastSpam
http://www.lastspam.com
easy
View this message in context: http://n2.nabble.com/configure-geonetwork-tp4176015p4180424.html
A streamlined, 14 day to market process makes app distribution fast and easy
__________________________________________________________________________________
See what's on at the movies in your area. Find out now: http://au.movies.yahoo.com/session-times/
