[GeoNetwork-users] configure resources and metadata over rest
We are thinking about using geonetwork. But because we have plenty of geodata to manage manually I am wondering if there is a rest interface to setup and configure the provided metada.
Like in geoserver, where you are able to configure layers, workspaces, and everything else over get and post requests.
Marco Scheuble
MSc. Geographie | Entwicklung
GEOINFO IT AG | Kasernenstrasse 69 | 9100 Herisau | Tel. +41 71 353 53 99 | www.geoinfo.ch
[cid:image001.jpg@anonymised.com]<https://www.geoinfo.ch/index.php?id=15&tx_wsproductsgeoinfo_solutions[solution]=74&tx_wsproductsgeoinfo_solutions[action]=show&tx_wsproductsgeoinfo_solutions[controller]=Solution&cHash=ca9e7de867e99085f3df59aed79fb424&gt;
(attachments)
Sure there is! :slight_smile:
Until and including version 3.0.x you had the services listed here:
   http://geonetwork-opensource.org/manuals/2.10.4/eng/developer/xml_services/index.html
Programmatically you could use the geonetwork-manager java library:
   https://github.com/geosolutions-it/geonetwork-manager
In GN version 3 the API has been reorganized; the documentation is created on the fly, so you'll have the list of available operations on any running instance at
http://YOURSERVER/geonetwork/doc/api,
e.g. the main operation groups:
   http://maps.aqua.wisc.edu/geonetwork/doc/api/
or e.g.: the operation for adding a metadata record:
   http://maps.aqua.wisc.edu/geonetwork/doc/api/#!/records/insertFile
   Emanuele
Alle 09:35:37 di Thursday 6 July 2017, Scheuble Marco GEOINFO ha scritto:
setup and configure the provided metada. Like in geoserver, where you are
post requests.
Marco Scheuble
www.geoinfo.ch
&tx_wsproductsgeoinfo_solutions%5Bsolution%5D=74&tx_wsproductsgeoinfo_solut
ions%5Baction%5D=show&tx_wsproductsgeoinfo_solutions%5Bcontroller%5D=Soluti
on&cHash=ca9e7de867e99085f3df59aed79fb424>
Emanuele Tajariol
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Emanuele Tajariol
Technical Lead
Via di Montramito 3/A
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è
consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il
destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or
proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in
accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous
formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete
the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
