[GeoNetwork-users] contribute > import new records
Greetings — We are having difficulty importing new records via XML in GeoNetwork v3.0.0:
(1) When we try to upload a file, the upload process seems to work, then provides “Import Report” with no additional text, then no record is added.
(2) When we do copy/paste, we get an error import report ("{"error": { "message": "Autodetecting schema failed for metadata record with root element metadata in namespace [Namespace: prefix "" is mapped to URI “”]…”)
We have attempted this for several xml metadata records, so we don’t believe the problem was with the metadata.
Sure appreciate your assistance,
Jim P.
James D. Proctor, Professor & Director
Environmental Studies Program
348 JR Howard Hall
Lewis & Clark College
0615 SW Palatine Hill Road, MSC 62
Portland, OR 97219
jproctor@anonymised.com
503.768.7707
Just hoping to get an update on below, as we have quite a few metadata records to import this wk. If there is something simple I’m missing, please advise.
Jim P.
Jim P.
348 JR Howard Hall
Portland, OR 97219
503.768.7707
Hi Jim,
Can you be specific about your metadata format. It might be easier to
location your problem if you can paste part of your metadata here. And also,
have you tried "uncheck validate".
Best,
Cody
Geospatial discovery and cyberinfrastructure
View this message in context: http://osgeo-org.1560.x6.nabble.com/contribute-import-new-records-tp5209238p5209822.html
Hi Jim,
Can you be specific about what metadata format you are using? It might be
easier to locate your problem if you can past a snippet of your metadata
here.
Best,
Cody
View this message in context: http://osgeo-org.1560.x6.nabble.com/contribute-import-new-records-tp5209238p5209824.html
Any chance that you are using ISO 19115-2?
GeoNetwork v3.0.0:
Jim P.
348 JR Howard Hall
Portland, OR 97219
503.768.7707
GeoNetwork-users mailing list
Jacqueline Mize
Metadata Specialist
Riverside Technology, Inc.
NOAA National Centers for Environmental Information
1021 Balch BLVD, Suite 1002
Stennis Space Center, MS 39529
email: Jacqueline.Mize@anonymised.com
ph: 228.688.2174
Jacqueline and Cody, sure appreciate your responses, and I’m red-faced as I didn’t check the std at bottom of xml, which in both trial cases turned out to be FGDC. I then searched and found this FGDC to ISO-19115 import conversion script:
http://dak1n1.com/blog/1-automating-gis-metadata-conversion/
and installed/invoked it, and the import worked!
Question: is there a more recent FGDC to ISO-19115 conversion script for GeoNetwork? The above was distributed in 2011.
Many thanks,
Jim P.
348 JR Howard Hall
Portland, OR 97219
503.768.7707
On June 8, 2015 at 12:02:45, Jacqueline Mize - NOAA Affiliate (jacqueline.mize@anonymised.com) wrote:
Jim P.
348 JR Howard Hall
Portland, OR 97219
503.768.7707
Jacqueline Mize
Metadata Specialist
Information
ph: 228.688.2174
Jim,
I know of a FGDC to ISO 19115-2 transform that is external from GeoNetwork
located at
ftp://ftp.ncddc.noaa.gov/pub/Metadata/Online_ISO_Training/Intro_to_ISO/transforms/
(there are several depending on which FGDC profile is used) and there is an
online conversion tool at https://www.ngdc.noaa.gov/docucomp/recordServices
conversion script:
Many thanks,
Jim P.
  James D. Proctor
<https://college.lclark.edu/faculty/members/james_proctor/&gt;, Professor &
Director
<https://college.lclark.edu/programs/environmental_studies/&gt;
348 JR Howard Hall
  Lewis & Clark College <https://www.lclark.edu>
Portland, OR 97219
503.768.7707
GeoNetwork v3.0.0:
Jim P.
348 JR Howard Hall
Portland, OR 97219
503.768.7707
  Jacqueline Mize
Metadata Specialist
ph: 228.688.2174
Jacqueline Mize
Metadata Specialist
ph: 228.688.2174
Update: I’m no longer able to duplicate the successful test noted below, using either the FGDC record I previously imported, nor an ISO 19115-2 version converted via
I’ve restarted Tomcat a few times (this has cleared up certain admin glitches in past), tried other metadata records, etc…no luck.
Is there an error log I could browse in order to more fully diagnose? It was working so well…that one time ;-).
Jim P.
Many thanks,
Jim P.
348 JR Howard Hall
Portland, OR 97219
503.768.7707
Jim P.
348 JR Howard Hall
Portland, OR 97219
503.768.7707
Jacqueline Mize
Metadata Specialist
Information
ph: 228.688.2174
Looks like you issue was about metadata format. Since you didn't describe
your error, it hard to give any advice. Did you change anything afterwards?
The easier way is to look at the dos window (restart GNK) and see what it
says. I personally don't like that black window, but sometimes it helps.
Cody
View this message in context: http://osgeo-org.1560.x6.nabble.com/contribute-import-new-records-tp5209238p5209852.html
