[GeoNetwork-users] Converting existing metadata in preferred vector ISO19139 foramt to multilingual vector ISO19139
Hi there,
I was wondering if there is a function within GN to convert existing
metadata records that are saved in the preferred (single language) ISO19139
format to the multilingual ISO19139 format. I can't see a stylesheet to
select if importing as an XML file.
Rich
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Converting-existing-metadata-in-preferred-vector-ISO19139-foramt-to-multilingual-vector-ISO19139-tp6102544p6102544.html
I can add multilingual functionality to an individual metadata record using
the guidance contained in ~web/geonetwork/xsl/metadata-iso19139.xsl, which
involves inserting the gmd:locale and editing gmd:title elements. E.g.,
    eng
and
            Template for Vector data in ISO19139 (preferred!)
                Enter title here
Is there a method to do this for a batch of records?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Converting-existing-metadata-in-preferred-vector-ISO19139-format-to-multilingual-vector-ISO19139-tp6102544p6110325.html
I'm able to convert an existing ISO19139 record into multilingual record by
inserting the following elements into each record (as per guidelines in
~web/geonetwork/xsl/metadata-iso19139.xsl (see attached file).
http://osgeo-org.1803224.n2.nabble.com/file/n6112504/multilingual_insertion.txt
Is there a method to do this automatically for converting for a batch of
records?
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Converting-existing-metadata-in-preferred-vector-ISO19139-format-to-multilingual-vector-ISO19139-tp6102544p6112504.html
