[GeoNetwork-users] Could not compile stylesheet
I started to try to use geonetwork today!
Everthing installed smoothly, and started the server with no problems!But when I try to access the geonetwork web page it gives the error
"Tranformation exception
Could not compile stylesheet"
And the log showed this error
ERROR: 'file:///G:/Programas/geonetwork_desktop/web/xsl/metadata-iso19115.xsl:
line 1734: Template 'displayTab' not defined in this stylesheet.'
FATAL ERROR: 'Could not compile stylesheet'"
I can´t see the problem, cause i'm an newbie at this, so any help would be appreciated!
thanks in advance
best regards
hugo santos
Hi! This is related to the use of Java 1.5 instead of 1.4. You can find a FAQ explaining the problem and solution on the community website in the documentation section. http://geonetwork.sourceforge.net
Good luck.
Jeroen
On 3 Jan 2006, at 13:25, hdsantos@...48... wrote:
thanks in advance
best regards
hugo santos
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
Compare, Download & Develop Open Source & Business Software - SourceForge
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
