[GeoNetwork-users] creating empty structure in database
Hello,
I installed new version of Geonetwork 3.0.2 on Linux Oracle 6.5 x64
Geonetwork works ok with H2 database and sample data.
But when I tried to configure connection to Postgres or Oracle empty databases I've got error:
"HTTP ERROR: 503 Problem accessing /geonetwork/srv/pol/catalog.search Reason: Service Unavailable"
I' ve made changes in 2 files according to this page:
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/configuring-database.html
So how can set a connection to empty databases and how can I create empty structure of tables in Postgres or Oracle ?
In older versions of Geonetwork there was file e.g.: create-db-postgres.sql by means of I can build all structure of tables in database.
In version 3.0.2 I can't find it. There is only file data-db-default.sql (and loc files) with inserts.
Piotr
Hi
2015-09-11 15:04 GMT+02:00 Piotr Pachół <piotrpachol@anonymised.com>:
Hello,
in database.
No SQL anymore for that "The database default structure will be created by
the application on startup."
See
HTH.
Francois
Piotr
GeoNetwork-users mailing list
Hello,
Thanks for answer. But I still have a problem with starting Geonetwork with Postgres/Postgis.
I attached log file. What can I do with this ?
Regards
/2015-09-18 00:08:00,437 FATAL [jeeves.engine] - Raised exception during init
2015-09-18 00:08:00,437 FATAL [jeeves.engine] - Exception : org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [jar:file:/usr/local/geonetwork/web/geonetwork/WEB-INF/lib/domain-3.0.2-0.jar!/config-spring-geonetwork.xml]: Cannot resolve reference to bean 'jdbcDataSource' while setting bean property 'dataSource'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jdbcDataSource' defined in URL [file:/usr/local/geonetwork/web/geonetwork/WEB-INF/config-db/jndi-postgres-postgis.xml]: Invocation of init method failed; nested exception is javax.naming.NameNotFoundException; remaining name 'env'
2015-09-18 00:08:00,437 FATAL [jeeves.engine] - Message : Error creating bean with name 'entityManagerFactory' defined in URL [jar:file:/usr/local/geonetwork/web/geonetwork/WEB-INF/lib/domain-3.0.2-0.jar!/config-spring-geonetwork.xml]: Cannot resolve reference to bean 'jdbcDataSource' while setting bean property 'dataSource'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jdbcDataSource' defined in URL [file:/usr/local/geonetwork/web/geonetwork/WEB-INF/config-db/jndi-postgres-postgis.xml]: Invocation of init method failed; nested exception is javax.naming.NameNotFoundException; remaining name 'env'
2015-09-18 00:08:00,439 FATAL [jeeves.engine] - Stack : org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [jar:file:/usr/local/geonetwork/web/geonetwork/WEB-INF/lib/domain-3.0.2-0.jar!/config-spring-geonetwork.xml]: Cannot resolve reference to bean 'jdbcDataSource' while setting bean property 'dataSource'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jdbcDataSource' defined in URL [file:/usr/local/geonetwork/web/geonetwork/WEB-INF/config-db/jndi-postgres-postgis.xml]: Invocation of init method failed; nested exception is javax.naming.NameNotFoundException; remaining name 'env'
     at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
     at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1417)
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1158)
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458)
     at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:296)
     at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223)
     at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:293)
     at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194)
     at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1117)
     at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:922)
     at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479)
     at jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:56)
     at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:782)
     at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:424)
     at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:774)
     at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:249)
     at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1242)
     at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:717)
     at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:494)
     at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
     at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:39)
     at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
     at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:494)
     at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:141)
     at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:145)
     at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:56)
     at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:615)
     at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:540)
     at org.eclipse.jetty.util.Scanner.scan(Scanner.java:403)
     at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:337)
     at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:121)
     at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:555)
     at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:230)
     at org.eclipse.jetty.util.component.AggregateLifeCycle.doStart(AggregateLifeCycle.java:81)
     at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:58)
     at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:96)
     at org.eclipse.jetty.server.Server.doStart(Server.java:282)
     at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1274)
     at java.security.AccessController.doPrivileged(Native Method)
     at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1197)
     at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
     at java.lang.reflect.Method.invoke(Method.java:606)
     at org.eclipse.jetty.start.Main.invokeMain(Main.java:473)
     at org.eclipse.jetty.start.Main.start(Main.java:615)
     at org.eclipse.jetty.start.Main.main(Main.java:96)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jdbcDataSource' defined in URL [file:/usr/local/geonetwork/web/geonetwork/WEB-INF/config-db/jndi-postgres-postgis.xml]: Invocation of init method failed; nested exception is javax.naming.NameNotFoundException; remaining name 'env'
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1512)
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:521)
     at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
     ... 52 more
Caused by: javax.naming.NameNotFoundException; remaining name 'env'
     at org.eclipse.jetty.jndi.NamingContext.lookup(NamingContext.java:449)
     at org.eclipse.jetty.jndi.NamingContext.lookup(NamingContext.java:536)
     at org.eclipse.jetty.jndi.NamingContext.lookup(NamingContext.java:551)
     at org.eclipse.jetty.jndi.java.javaRootURLContext.lookup(javaRootURLContext.java:117)
     at javax.naming.InitialContext.lookup(InitialContext.java:411)
     at org.springframework.jndi.JndiTemplate$1.doInContext(JndiTemplate.java:154)
     at org.springframework.jndi.JndiTemplate.execute(JndiTemplate.java:87)
     at org.springframework.jndi.JndiTemplate.lookup(JndiTemplate.java:152)
     at org.springframework.jndi.JndiTemplate.lookup(JndiTemplate.java:178)
     at org.springframework.jndi.JndiLocatorSupport.lookup(JndiLocatorSupport.java:95)
     at org.springframework.jndi.JndiObjectLocator.lookup(JndiObjectLocator.java:105)
     at org.springframework.jndi.JndiObjectFactoryBean.lookupWithFallback(JndiObjectFactoryBean.java:231)
     at org.springframework.jndi.JndiObjectFactoryBean.afterPropertiesSet(JndiObjectFactoryBean.java:217)
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1571)
     at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1509)
     ... 59 more/
W dniu 2015-09-16 o 10:21, Francois Prunayre pisze:
Hi
2015-09-11 15:04 GMT+02:00 Piotr Pachół <piotrpachol@anonymised.com <mailto:piotrpachol@anonymised.com>>:
> Hello,
> in database.
No SQL anymore for that "The database default structure will be created by the application on startup."
See http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/configuring-database.html
HTH.
Francois
> Regards,
> Piotr
> GeoNetwork-users@lists.sourceforge.net <mailto:GeoNetwork-users@lists.sourceforge.net>
> GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Hello,
I made many attempts to configure Geonetwork 3.0.2 with Oracle or Postgres/Postgis databases. (System: Linux Oracle 6.5 x64)
Still without success. Geonetwork works only with H2 database.
Logs for Oracle and Postgres are similar - as in the previous email.
Could you suggest something ?
Piotr
W dniu 2015-09-18 o 01:14, Piotr Pachół pisze:
Hello,
Regards
    ... 52 more
    ... 59 more/
Hi
> Hello,
> in database.
HTH.
Francois
> Regards,
> Piotr
Hi
I am struggling with exactly the same problem.
I think if anybody could help shed some light on this error, it might go a long way towards helping us with a solution ...
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [jar:file:/opt/apache-tomcat-8.0.22/webapps/geonetwork/WEB-INF/lib/domain-3.0.2-0.jar!/config-spring-geonetwork.xml]: Initialization of bean failed; nested exception is org.springframework.beans.ConversionNotSupportedException: Failed to convert property value of type 'org.apache.naming.NamingContext' to required type 'javax.sql.DataSource' for property 'dataSource'; nested exception is java.lang.IllegalStateException: Cannot convert value of type [org.apache.naming.NamingContext] to required type [javax.sql.DataSource] for property 'dataSource': no matching editors or conversion strategy found
Erik
-----Original Message-----
From: Piotr Pachół [mailto:piotrpachol@anonymised.com]
Sent: 24 September 2015 10:53 AM
To: Francois Prunayre <fx.prunayre@anonymised.com>
Cc: geonetwork-users <geonetwork-users@lists.sourceforge.net>
Subject: Re: [GeoNetwork-users] creating empty structure in database
Hello,
I made many attempts to configure Geonetwork 3.0.2 with Oracle or Postgres/Postgis databases. (System: Linux Oracle 6.5 x64) Still without success. Geonetwork works only with H2 database.
Piotr
Hello,
Regards
during init
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    ... 52 more
    at
    at
    at
    at
    at
    at
    at
    at
    ... 59 more/
Hi
> Hello,
> tables in database.
data-db-default.sql
See
HTH.
Francois
> Regards,
> Piotr
Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
Get real-time metrics from all of your servers, apps and tools in one place.
SourceForge users - Click here to start your Free Trial of Datadog now!
http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
