Dear Piotr
My memory is pretty bad – see the discussion below…. I have been through this before with Francois.
The problem is with the JNDI configuration… but there doesn’t seem to be any solution yet. The good news is that I did get it working with postgis.
Erik
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: 12 May 2015 12:53 PM
To: Erik Voges <erik.voges@anonymised.com>
Cc: Geonetwork-Users@anonymised.com
Subject: Re: [GeoNetwork-users] create scripts in 3.0
Ok so there is probably something wrong with JNDI or the JNDI configuration. Anyone having JNDI working with version 3?
Francois
2015-05-12 13:50 GMT+02:00 Erik Voges <erik.voges@anonymised.com <mailto:erik.voges@anonymised.com> >:
It was a good idea, thanks Francois
I switched to “postgres” and it started up, without any obvious problems. This automatically ran the “create” script as you explained and successfully created all the tables in my database. The application was running successfully.
I enabled the postgis extensions on the database (postgis and postgis-topology) and switch back to the jndi-postgres-postgis.xml mechanism … but I encountered the same error as before.
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com> fx.prunayre@...54...]
Sent: 12 May 2015 11:22 AM
To: Erik Voges
Cc: Geonetwork-Users@anonymised.com <mailto:Geonetwork-Users@anonymised.com>
2015-05-12 12:11 GMT+02:00 Erik Voges <erik.voges@anonymised.com <mailto:erik.voges@anonymised.com> >:
Thanks Francois
1.) I have changed the ../WEB-INF/config-node/srv.xml file and uncommented this line:
<import resource="../config-db/jndi-postgres-postgis.xml"/>
If doing step by step, I would try first to enable postgres
<import resource="../config-db/postgres.xml"/>
then enable postgis
and then move to JNDI.
2.) I have changed my jdbc.properties as follows:
jdbc.username=postgres
jdbc.password=secret_password
jdbc.database=geonetwork
jdbc.host=localhost
jdbc.basic.removeAbandoned=true
jdbc.basic.removeAbandonedTimeout=120
jdbc.basic.logAbandoned=true
jdbc.basic.maxActive=33
jdbc.basic.maxIdle=${jdbc.basic.maxActive}
jdbc.basic.initialSize=${jdbc.basic.maxActive}
jdbc.basic.maxWait=200
jdbc.basic.testOnBorrow=true
jdbc.basic.timeBetweenEvictionRunsMillis=10000
jdbc.basic.minEvictableIdleTimeMillis=1800000
jdbc.basic.testWhileIdle=true
jdbc.basic.numTestsPerEvictionRun=3
jdbc.basic.poolPreparedStatements=true
jdbc.basic.maxOpenPreparedStatements=1200
jdbc.basic.validationQuery=SELECT 1
jdbc.basic.defaultReadOnly=false
jdbc.basic.defaultAutoCommit=false
3.) I have created the geonetwork database (not sure if I should have named it something else ..?)
4.) Next I changed my ../WEB-INF/config-db/jndi-postgres-postgis.xml file as follows (changed the value of jndiName):
<bean id="jdbcDataSource" class="org.springframework.jndi.JndiObjectFactoryBean">
<property name="jndiName" value="java:/comp/env/jdbc/PostGIS"/>
<property name="cache" value="true"/>
<property name="exposeAccessContext" value="false"/>
</bean>
5.) I have also added this section inside my …/tomcat/conf/context.xml file, inside the <context> tags.
<Resource name="jdbc/PostGIS" auth="Container" type="javax.sql.DataSource"
driverClassName="org.postgresql.Driver" url="jdbc:postgresql://localhost:5432/geonetwork?relaxAutoCommit=true" username="postgres" password="5455c4l_" maxActive="200" maxIdle="50" maxWait="10000" />
6.) And I have replaced the postgres driver in ../WEB-INF/lib - postgresql-9.1-901.jdbc4.jar with a later version - postgresql-9.4-1201.jdbc41.jar , because I had some errors of a method that wasn’t implemented – this seems to have fixed it.
Would be good to open ticket on github with description and error message
https://github.com/geonetwork/core-geonetwork/issues
to have this fixed in future release.
Thanks.
Francois
… and now I am here with the big rock in the middle of the road J
I am not sure if steps 4 and 5 were required… I tried it without those changes, but then I got this error:
12-May-2015 12:10:06.099 INFO [localhost-startStop-2] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [jar:file:/opt/apache-tomcat-8.0.22/webapps/geonetwork/WEB-INF/lib/domain-3.0.0-0.jar!/config-spring-geonetwork.xml]: Initialization of bean failed; nested exception is org.springframework.beans.ConversionNotSupportedException: Failed to convert property value of type 'org.apache.naming.NamingContext' to required type 'javax.sql.DataSource' for property 'dataSource'; nested exception is java.lang.IllegalStateException: Cannot convert value of type [org.apache.naming.NamingContext] to required type [javax.sql.DataSource] for property 'dataSource': no matching editors or conversion strategy found
Thanks for your help
Erik
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com <mailto:fx.prunayre@…54…> ]
Sent: 12 May 2015 10:21 AM
To: Erik Voges
Subject: Re: [GeoNetwork-users] create scripts in 3.0Hi Erik,
2015-05-12 11:03 GMT+02:00 Erik Voges <erik.voges@anonymised.com <mailto:erik.voges@anonymised.com> >:
Dear Community
I have installed version 3.0 and I am trying to switch from H2 to a postgis
database.When I start up my app in the Tomcat manager, I get these errors (among
others) :2015-05-12 10:35:27,936 WARN [geonetwork] - Database does not contain
any version information. Check that the database is a GeoNetwork database
with data. Migration step aborted.org.springframework.beans.factory.BeanCreationException: Error creating bean
0.0-0.jar!/config-spring-geonetwork.xml]: Cannot resolve reference to bean
'jdbcDataSource' while setting bean property 'dataSource'; nested exception
is org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'jdbcDataSource': Post-processing of the FactoryBean's object
failed; nested exception is java.lang.RuntimeException:
org.postgresql.util.PSQLException: Cannot commit when autoCommit is enabled.at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolv
eReference(BeanDefinitionValueResolver.java:329)at
eValueIfNecessary(BeanDefinitionValueResolver.java:107)at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory
.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1417)at
.populateBean(AbstractAutowireCapableBeanFactory.java:1158)at
.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)at
.createBean(AbstractAutowireCapableBeanFactory.java:458)at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(Ab
stractBeanFactory.java:296)How did you configure the db connection ?
http://osgeo-org.1560.x6.nabble.com/Configure-Data-Base-version-3-td5203785.html#a5203932 may help
Now, I noticed that the directory with database create scripts is not
included in the war file .
/tomcat/webapps/geonetwork/WEB-INF/classes/setup/sql/ - this directory only
has "data" and "migrate" subdirectories. I wanted to run the create scripts
manually to see if that would resolve my problem . but they are not there.I have the previous version installed on another local server - it has the
"create" directory and scripts. Would it be ok if I use that for creating a
database for the v3.0 server? Where else would I be able to find the create
scripts for a v3.0 postgis database?The database in 3.0 is create by the application (JPA) so there is no SQL script for the structure. Only a script to populate the data and to handle migration in case JPA can not deal with it.
HTH
Francois
Many thanks
Erik
Erik Voges
Systems Engineer - OADC/KEDISCLAIMER & COPYRIGHT
This email and any accompanying attachments may contain confidential,
proprietary information and attached artwork which is subject to
international copyright laws. This information is private and protected by
law and, accordingly if you are not the intended recipient, you are
requested to delete this entire communication immediately and are notified
that any disclosure, copying or distribution of or taking any action based
on this information is prohibited.------------------------------------------------------------------------------
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net <mailto:GeoNetwork-users@anonymised.comrceforge.net>
