Hi there,
I'd like to create a new advanced search field, with a drop down menu
populated with organisation names input from ISO19139 records. At the moment
the menu is not being populated with organisation names after amending the
following two files. I'd be really grateful if someone could advise.
1. Code inserted into searchform_advanced.xsl
2. I've also added the following lines (unsure if necessary) into
~geonetwork/scripts/gn_search.js
pars += fetchParam('orgName');
setParam('orgName','');
Thanks for your support.
Rich
PS. it would be useful to have some guidelines on developing new search
fields which could be applied to other metadata elements. I'll summarise for
the above 'organisation name' example. Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Creating-new-advanced-search-field-for-organisation-names-tp6189257p6189257.html
