[GeoNetwork-users] CSW 2.0.2 support checked in
I've now gotten the code to support CSW 2.0.2 checked into subversion. I've also done an update to a copy of the code I had checked out on a Windows box here and tested it. It passes all but one of the OWS-5 CITE tests on that platform (and passes every test on my Fedora Linux box). The one test that fails is the request for record validation using GetRecords and I suspect it's a Windows problem and not an issue with the CSW code, but I'll investigate.
I'm sure there are things that can stand to be cleaned up, but the CSW code ought to be largely functional now. I'll be happy to see improvements and/or corrections added to the distribution.
Archie
-- Archie Warnock warnock@anonymised.com
-- A/WWW Enterprises www.awcubed.com
-- As a matter of fact, I _do_ speak for my employer.
