I would like to know if GeoNetwork (current version) has implemented the
optional function Xpath in the CSW / GetRecords operation for the
ElementName attribute.
This parameter could be used to reference to a specific XML element for the
getRecord response instead to a ³predefined² schema (summary, brief,...).
In the case, the response contains only the content of XML element of each
metadata compliance with the search request.
Pierre, BRGM
Pensez a l'environnement avant d'imprimer ce message
Think Environment before printing
Le contenu de ce mel et de ses pieces jointes est destine a l'usage exclusif du (des) destinataire(s) designe
(s) comme tel(s).
En cas de reception par erreur, le signaler e son expediteur et ne pas en divulguer le contenu.
L'absence de virus a ete verifiee e l'emission, il convient neanmoins de s'assurer de l'absence de
contamination a sa reception.
The contents of this email and any attachments are confidential. They are intended for the named recipient
(s) only.
If you have received this email in error please notify the system manager or the sender immediately and do
not disclose the contents to anyone or make copies.
eSafe scanned this email for viruses, vandals and malicious content.
