[GeoNetwork-users] CSW differences 2.6 vs 2.8
Hi Guys
We have a CSW client working fine against the 2.6.3/4 series but on a recent
upgrade to 2.8, nothing seems to work.
Can you please let us know what has changed on the API and where the
migration document is?
Terry Rankine
View this message in context: http://osgeo-org.1560.x6.nabble.com/CSW-differences-2-6-vs-2-8-tp5047128.html
I've also discovered a few differences, the major ones:
* What happened to the typeName csw:IsoRecord? I can see csw:Record but that appears to be for a Dublin core metadata record
* Is HTTP POST still supported? I can only seem to get responses using a HTTP GET now.
Josh Vote
-----Original Message-----
From: Terry Rankine [mailto:terry.rankine@anonymised.com]
Sent: Tuesday, 16 April 2013 11:47 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [ExternalEmail] [GeoNetwork-users] CSW differences 2.6 vs 2.8
Hi Guys
We have a CSW client working fine against the 2.6.3/4 series but on a recent upgrade to 2.8, nothing seems to work.
Can you please let us know what has changed on the API and where the migration document is?
Terry Rankine
Precog is a next-generation analytics platform capable of advanced analytics on semi-structured data. The platform includes APIs for building apps and a phenomenal toolset for data science. Developers can use our toolset for easy data analysis & visualization. Get a free account!
http://www2.precog.com/precogplatform/slashdotnewsletter
GeoNetwork-users mailing list
Please disregard my earlier email, it appears my CSW request was faulty but the earlier GN versions were tolerant of the errors. I've since updated my parameters to read:
typeNames= gmd:MD_Metadata
outputSchema= csw:IsoRecord
And the CSW request issues have since been alleviated.
Josh
From: Josh.Vote@anonymised.com [mailto:Josh.Vote@anonymised.com]
Sent: Tuesday, 16 April 2013 12:50 PM
Subject: Re: [GeoNetwork-users] [ExternalEmail] CSW differences 2.6 vs 2.8
Josh Vote
Hi Guys
Terry Rankine
Ahh - where did you get those keywords from? Can you share the post body you
are using?
I had a look at the testCSW client built into geonetwork and there is an
example there.
http://example.org/geonetwork/srv/eng/test.csw
is this the example you are using?
It turns out that I was not setting a few of the parameters (although 2.6
never really minded for some reason...)
Terry
View this message in context: http://osgeo-org.1560.x6.nabble.com/CSW-differences-2-6-vs-2-8-tp5047128p5047146.html
hi,
I realize the handling of CSW requests can be somewhat confusing, due to
vagueness or inconsistency in the specifications, choices made by
GeoNetwork in those cases, and certain GeoNetwork-specific implementations.
In general I would advice to compose CSW request as much as possible
according to the specs in OGC 07-006 and OGC 07-045.
I'll try to describe how things are :
about typeNames:
see http://trac.osgeo.org/geonetwork/ticket/724 for some description on the
changes to handling of typeNames in combination with ElementName.
The value of typeNames should be either csw:Record or gmd:MD_Metadata
(though the namespace prefix can be different if you mapped it differently).
This is conform OGC 07-045 8.2.2.1.1: "Mandatory: Must support *one* of
“csw:Record” or “gmd:MD_Metadata” in a query. Default value is
“csw:Record”."
Note how OGC 07-045 mixes up a mandatory parameter that has a default value
! GeoNetwork goes for the more permissive default value option, rather than
the mandatory-ness. So: if typeNames is not present or empty, "csw:Record"
is used.
If the request does not contain exactly one (or both, comma-separated) of
these values specified in OGC 07-045, an exception is thrown. If both are
present "gmd:MD_Metadata" is preferred.
about outputSchema:
the value of outputSchema can be:
missing -- treated as Record ;
csw:Record -- treated as Record
csw:IsoRecord -- treated as IsoRecord
(according to me those two values above are invalid and should actually be
rejected, to comply with the specifications)
http://www.opengis.net/cat/csw/2.0.2 -- treated as Record
http://www.isotc211.org/2005/gmd -- treated as IsoRecord
Any other value causes the request to be rejected.
See OGC 07-006 10.8.4.5 and OGC 07-045 for specifications.
additional note about ElementNames:
In case you use ElementNames (note the plural -- not ElementName), there
are the following options:
     * For ElementNames, several strategies are implemented. Clients can
determine the behaviour by sending attribute
     * "elementnameStrategy" with one of the following values:
     * csw202
     * relaxed
     * context
     * geonetwork26
     * The default is 'relaxed'. The strategies cause the following
behaviour:
     * csw202 -- compliant to the CSW2.0.2 specification. In particular
this means that complete metadata are returned
     * that match the requested ElementNames, only if they are
valid for their XSD. This is because
     * GeoNetwork only supports OutputFormat=application/xml,
which mandates that valid documents are
     * returned. Because possibly not many of the catalog's
metadata are valid, this is not the default.
     * relaxed -- like csw202, but dropped the requirement to only include
valid metadata. So this returns complete
     * metadata that match the requested ElementNames. This is
the default strategy.
     * context -- does not return complete metadata but only the elements
matching the request, in their context (i.e.
     * all ancestor elements up to the root of the document are
retained). This strategy is similar to
     * geonetwork26 but the context allows clients to determine
which of the elements returned corresponds to
     * which of the elements requested (in case they have the
same name).
     * geonetwork26 -- behaviour as in GeoNetwork 2.6. Just return the
requested elements, stripped of any context. This
     * can make it impossible for the client to determine
     * which of the elements requested; for example if the
client asks for gmd:title, the response may
     * contain various gmd:title elements taken from
different locations in the metadata document.
See OGC 07-006 10.8.4.8, OGC 07-045 8.2.2.1.1, and OGC 07-006 10.8.4.9 for
specifications.
I hope this helps,
kind regards
Heikki Doeleman
On Tue, Apr 16, 2013 at 8:00 AM, Terry Rankine <terry.rankine@anonymised.com>wrote:
you
are using?
example there.
Terry
