[GeoNetwork-users] csw: get record by property name
Thank you. It works. Sorry for bothering you (I should read carefully first the specification before writing).
Finally, I am using the "keyword" field in order to relate metadata records with its corresponding OGC resources. I decided to add the code of the resource as another keyword. Later, I can get the metadata for a specific OGC resource using the following query:
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; service="CSW" version="2.0.2" outputFormat="application/xml" resultType="results">
<csw:Query typeNames="csw:Record">
<csw:Constraint version="1.1.0">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns="http://www.opengis.net/ogc&quot;&gt;
<ogc:PropertyIsEqualTo matchCase="false">
<ogc:PropertyName>Subject</ogc:PropertyName>
<ogc:Literal>code_of_the_resource</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
----- Original Message -----
Sent: 01/12/11 09:49 AM
To: Robert Holland
Subject: Re: [GeoNetwork-users] csw: get record by property name
Hi Robert
Add resultType="results" in request, that should return the results:
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; service="CSW" version="2.0.2" outputFormat="application/xml" resultType="results" >
Jose García
GeoCat bv
On Wed, Jan 12, 2011 at 9:49 AM, Robert Holland <robert.holland@anonymised.com> wrote:
Thank you for your help. After reading the GetCapabilities information, it appears that there is no a queryable field related to the "Code" showed in the section "Identification Info". My aim was to use this field for storing the name of the OGC resource. In this way I would have a way for relating OGC resources with their metadata records. What field could be used for this purpose?
Moving on to something else, does it right that the "GetRecords" request just returns information about the number of the records matched and not the XML that represents them? For example, when I run a query I get the following XML:
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd&quot;&gt;
<csw:SearchStatus timestamp="2011-01-12T08:52:58" />
<csw:SearchResults numberOfRecordsMatched="2" numberOfRecordsReturned="0" elementSet="summary" nextRecord="1" />
</csw:GetRecordsResponse>
It says that the query matched two records but it doesn't return the XML of these records.
Sent: 01/11/11 03:40 PM
To: Robert Holland
Hi Robert
The CSW Capabilities document returns the list of queryable fields in the GetRecords section.
You can find the mapping with field names to metadata properties in CSW 2.0.2 spec.
Jose García
On Tue, Jan 11, 2011 at 3:19 PM, Robert Holland <robert.holland@anonymised.com> wrote:
I am trying to get a record of the catalog by using the request &quot;GetRecords&quot;\. I don&#39;t know its metadata id, but the value of the field &quot;code&quot; that is showed in the section &quot;Identification Info&quot;\. To do so I am using the XML showed below\. It does return nothing\. I think that the problem is related to the name of the property that stores the code\. What is its internal name?
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; service="CSW" version="2.0.2" outputFormat="application/xml">
<ogc:PropertyName>code</ogc:PropertyName>
<ogc:Literal>roads03</ogc:Literal>
</ogc:Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Thank you\. Regards,
Robert\.
Gaining the trust of online customers is vital for the success of any company
that requires sensitive data to be transmitted over the Web. Learn how to
best implement a security strategy that keeps consumers' information secure
and instills the confidence they need to proceed with transactions.
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-users mailing list
