[GeoNetwork-users] CSW GetRecords and CSW GetRecordsByID for multilingual metadata
I have a question related to CSW behaviour with multilingual metadata.
I think that Geonetwork handles multilanguage metadata quite nice: for
instance, if I open GN and I choose the catalan language and I search for
metadata, the multilingual metadata are shown in catalan (that is, the
catalan "locale" metadata branches are shown instead of the default language
branches), if I change GN to french language, and I search for metadata, the
multilingual metadata are shown in french (that is, the french "locale"
branches are shown instead of the default language branches),and so on.
The question is, how can I get the same behaviour with *CSW *'*GetRecords*'
and '*GetRecordsByID*'. Can anybody give me some advice how to write the two
POST messages to receive the multilingual metadata *only in a specified
"locale" language* like the GN interface provides?
Thanks a lot for your help,
Best regards,
Montse
View this message in context: http://osgeo-org.1803224.n2.nabble.com/CSW-GetRecords-and-CSW-GetRecordsByID-for-multilingual-metadata-tp6524242p6524242.html
Hi Montse,
2011/6/28 mmarco <mmarcosabate@anonymised.com>:
Use the english CSW entry point
http://localhost:8080/geonetwork/srv/en/csw
or the french
http://localhost:8080/geonetwork/srv/fr/csw
or others
and if CSW requests ask for dublincore output, you'll get metadata
content according to the entry point URL (like in the GUI).
If you ask for ISO record in output, then the client has to look for
the translation in the ISO PT_FreeText elements.
Cheers.
Francois
Best regards,
Montse
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
GeoNetwork-users mailing list
-----Original Message-----
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: Tuesday, 28 June 2011 06:03
To: mmarco
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] CSW GetRecords and CSW
Hi Montse,
> Hi,
quite nice: for
and I search
> for metadata, the multilingual metadata are shown in
catalan (that is,
> the catalan "locale" metadata branches are shown instead of the
> default language branches), if I change GN to french
language, and I
> search for metadata, the multilingual metadata are shown in
*'*GetRecords*'
to write
> the two POST messages to receive the multilingual metadata
*only in a
> specified "locale" language* like the GN interface provides?
or the french
or others
metadata content according to the entry point URL (like in the GUI).
look for the translation in the ISO PT_FreeText elements.
Francois: does GN CSW accept the Accept-Languages HTTP header? I'm also
guessing one can do this with a filter against apiso:Language (for
APISO).
..Tom
Hi Tom,
2011/6/28 Kralidis,Tom [Ontario] <Tom.Kralidis@anonymised.com>:
To: mmarco
Hi Montse,
> Hi,
quite nice: for
and I search
catalan (that is,
language, and I
*'*GetRecords*'
to write
*only in a
or the french
or others
No AFAIK.
I'm also
APISO).
Then you make a query on the language criteria but does not do any
filter on the content returned by the CSW response.
Cheers.
Francois
..Tom
