Hello everybody,
I just installed GeoNetwork this morning and received the "Hydrological Basins in Africa (Sample record, please remove!)" sample data, which I can search for via the web interface.
Now, I want to access the same catalogue entry via the GetRecords operation of the CSW interface.
Via the "CSW 2.0.1 test application" I can create the following request:
POST /geonetwork/srv/en/csw
User-Agent: Jakarta Commons-HttpClient/3.0.1
Host: localhost:8080
Content-Length: 636
Content-Type: application/xml; charset=UTF8
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw" service="CSW" version="2.0.1" resultType="results" startPosition="1" maxRecords="10">
<csw:Query>
<csw:ElementSetName>full</csw:ElementSetName>
<csw:Constraint version="1.1.0">
<Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml">
<PropertyIsLike wildCard="%" singleChar="_" escape="\">
<PropertyName>AnyText</PropertyName>
<Literal>%AFRICA%</Literal>
</PropertyIsLike>
</Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
This results to the response:
Date: Mon, 28 Jan 2008 16:26:02 GMT
Server: Jetty/5.1.5rc2 (Windows XP/5.1 x86 java/1.5.0_08
Expires: Thu, 01 Jan 1970 00:00:00 GMT
Set-Cookie: JSESSIONID=3n4opl7cqbi88;Path=/geonetwork
Pragma: no-cache
Cache-Control: no-cache
Expires: -1
Transfer-Encoding: chunked
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw">
<csw:SearchStatus status="complete" />
<csw:SearchResults numberOfRecordsMatched="0" numberOfRecordsReturned="0" elementSet="full" />
</csw:GetRecordsResponse>
What is a valid request to receive a match for the catalogue entry?
Best regards,
Desiree
Dr. Désirée Hilbring,
Fraunhofer IITB, Abteilung IMT,
Fraunhoferstr. 1, 76131 Karlsruhe, Germany
Telefon: +49(0)721/6091-463
mailto:hilbring@anonymised.com
http://www.iitb.fhg.de/
Hi Desiree,
For me, a filter such as :
<And>
<PropertyName>any</PropertyName>
<Literal>africa%</Literal>
</PropertyIsLike>
</And>
</Filter>
works fine using propertyName = any instead of AnyText. Maybe a more
general question is what kind of propertyName is supported by the csw
service of GeoNetwork ? is the search criteria of the main.search
service works with the csw service (ie. any, themekey, category, paper,
digital, title, abstract, bbox ...) ?
Thanks
Francois
Desiree Hilbring wrote:
Hello everybody,
Content-Length: 636
<csw:Query>
</PropertyIsLike>
</Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Pragma: no-cache
Expires: -1
Best regards,
Desiree
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-users mailing list
Hello Francois,
<And>
</PropertyIsLike>
</And>
</Filter>
a more general question is what kind of propertyName is
supported by the csw service of GeoNetwork ? is the search
criteria of the main.search service works with the csw
service (ie. any, themekey, category, paper, digital, title,
Yes that worked for me as well. Reading http://geonetwork-opensource.org/documentation/how-to/testing-the-ogc-csw-2-0-1-compliance, I assumed that the CSW interface would support
the core queryable properties of the CSW 2.0.1 Spec, Section 6.3.2.
That is not the case?
Where do I find a list of the search criteria of main.search?
Thanks Desiree
Thanks
Francois
> Hello everybody,
following request:
> Content-Length: 636
> <?xml version="1.0" encoding="UTF-8"?> <csw:GetRecords
maxRecords="10">
> <csw:Query>
> </PropertyIsLike>
> </Filter>
> </csw:Constraint>
> </csw:Query>
> </csw:GetRecords>
> Pragma: no-cache
> Expires: -1
> <?xml version="1.0" encoding="UTF-8"?> <csw:GetRecordsResponse
> Best regards,
> Desiree
> --- This SF.net email is sponsored by: Microsoft Defy all
challenges.
I don't know.
You could go to the main page, click on the "advanced" search and if
using Firefox, right click, page info, forms tab and advsearch forms.
Here you have all search criteria defined in the user interface.
Another option is to have a look to lucene.xml file.
HTH. Francois
Thanks Desiree
Thanks
Francois
Hello everybody,
following request:
Content-Length: 636
maxRecords="10">
<csw:Query>
</PropertyIsLike>
</Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Pragma: no-cache
Expires: -1
Best regards,
Desiree
