No one tested GetRecords?
Regards
Marco
(attachments)
forwarded message (3.68 KB)
Hi Marco,
I think the test example doesn't work in the client... Not a very good example indeed.
Jeroen
Regards
MarcoFrom: Marco Vimercati <mvimercati@anonymised.com>
Date: April 4, 2008 10:03:59 AM GMT+02:00
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] CSW - How to use GetRecordsHi all
I just installed GN 2.2 Final, before I was using the RCs.
I can't get the CSW working: GetCapabilities is Ok, but GetRecords returns
errors. I don't know there's a problem or I'm not able to use itI did the test with CSW test client, and that's the result with the
query "AnyText like %africa%" :========================================================0
Exception : org.fao.geonet.csw.common.exceptions.InvalidParameterValueEx:
code=InvalidParameterValue, locator=CqlText, message=AnyText like %africa%GET /geonetwork/srv/en/csw?request=GetRecords&service=CSW&version=2.0.1&namespace=csw%3Ahttp%3A%2F%2Fwww.opengis.net%2Fcat%2Fcsw&constraint=AnyText+like+%25africa%25&constraintLanguage=CQL_TEXT&constraint_language_version=1.1.0
User-Agent: Jakarta Commons-HttpClient/3.0.1
Host: localhost:8080
Cookie: JSESSIONID=CFB7BA17E13EF83A069DECE58B009D42==============================================================
OKServer: Apache-Coyote/1.1
Pragma: no-cache
Cache-Control: no-cache
Expires: -1
Content-Type: application/xml;charset=UTF-8
Transfer-Encoding: chunked
Date: Fri, 04 Apr 2008 08:02:43 GMT<?xml version="1.0" encoding="UTF-8"?>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows" version="1.0.0">
<ows:Exception exceptionCode="InvalidParameterValue" locator="CqlText">
<ows:ExceptionText>AnyText like %africa%</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>How can I user GetRecords? I want simply get all the records from the catalog.
Regards
Marco Vimercati-------------------------------------------------------------------------
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Jeroen,
I tryied with other queries, but I was never able to use GetRecords.
Can you provide me an example that works?
Best regards
Marco
Hi Marco,
example indeed.
> Regards
> Marco
> Hi all
> returns
> Exception :
> %africa%
> OK
> Pragma: no-cache
> Expires: -1
> version="1.0.0">
> locator="CqlText">
> </ows:Exception>
> the catalog.
> Regards
> Marco Vimercati
>ace _______________________________________________
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> http://sourceforge.net/projects/geonetwork
Marco Vimercati
Earth Observation Dept
Tel. +39.0238048.241
Fax +39.023086458
Email mvimercati@anonymised.com
Carlo Gavazzi Space S.p.A.
Via Gallarate, 150 - 20151 Milano MI - Italy
www.cgspace.it
<< Le informazioni contenute in questo messaggio di posta elettronica e
relativi allegati sono riservate e confidenziali e ne è vietata la diffusione
in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il
presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene
gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96
e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali
<< This e-mail is confidential and may well also be legally privileged. If you
have received it in error, you are on notice of its status. Please notify us
immediately by reply e-mail and then delete this message from your system.
Please do not copy it or use it for any purposes, or disclose its contents to
any other person: to do so could be a breach of confidence. Thank you for
your co-operation. Please contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici@anonymised.com if you need assistance>>
Jeroen,
Using the csw client and the following filter works for me :
<Filter xmlns="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml">
<PropertyIsLike wildCard="%" singleChar="_" escape="\">
<PropertyName>any</PropertyName>
<Literal>basin%</Literal>
</PropertyIsLike>
</Filter>
HTH. Francois
Thanks a lot!
Now I'm able to search metadata in the catalogue.
I confirm that the string
any = %
works, and retrieve all the metadata in the catalogue!
best regards
Marco
> Jeroen,
> Can you provide me an example that works?Using the csw client and the following filter works for me :
</PropertyIsLike>
</Filter>HTH. Francois
hello,
today I comitted a fix to the trunk such that AnyText is accepted.
regards
Heikki
Marco Vimercati-2 wrote:
Thanks a lot!
any = %
works, and retrieve all the metadata in the catalogue!best regards
MarcoMarco Vimercati wrote:
> Jeroen,
</PropertyIsLike>
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
View this message in context: http://www.nabble.com/Fwd%3A--CSW---How-to-use-GetRecords-tp16557305p21019132.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
