[GeoNetwork-users] CSW - mass insertion - crash
Hello Geonetwork Users,
we test load on the CSW. Therefore 54000 metadata sets are inserted directly via Transaction.Insert (programatically) into the CSW. Steps are login, insert, logout (login is required for insertion - can it be switched off??).
After dataset 24300 we got a Java Heap Space error.
The CSW did not work properly after that incident. So we shutdown the TC and got messages about lucene having still Threads open. Due to that, we waited some hours before starting TC again. TC did not startup properly. The CSW can not be reached now.
http://domain:8080/geonetwork/srv/en/csw?request=GetCapabilities&service=CSW&acceptVersions=2.0.2
returns an error page. The attachment contains the error messages mentioned.
What happend? What to do?
Is the GeoNetwork CSW capable of handling hundreds of thousand and even a million metadata entries? Where is the limit?
Greetings,
Kieran
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
(attachments)
mass-insertion-CSW-crash.docx (16.1 KB)
hello Kieran,
the restart did not work because a lock was left when the Heap Space error
occurred. Try stopping Tomcat, deleting
/opt/apache-tomcat-6.0.33-geonetwork/webapps/geonetwork/WEB-INF/lucene/nonspatial/write.lock
and then start Tomcat again.
Kind regards
Heikki Doeleman
off??).
mentioned.
Greetings,
Kieran
Ridiculously easy VDI. With Citrix VDI-in-a-Box, you don't need a complex
infrastructure or vast IT resources to deliver seamless, secure access to
virtual desktops. With this all-in-one solution, easily deploy virtual
desktops for less than the cost of PCs and save 60% on VDI infrastructure
costs. Try it free! http://p.sf.net/sfu/Citrix-VDIinabox
GeoNetwork-users mailing list
