Dear Mailinglist users,
I have an issue pretty similar to this one: http://sourceforge.net/p/geonetwork/mailman/geonetwork-users/thread/1377002018793-5073365.post%40n6.nabble.com/#msg31307007
I want to harvest a terraCatalog CSW with GN (running on an Ubuntu 14 server). From the above thread I concluded that the problem could be that the server isn't able to send a request, but that isn't the case here because firstly I talked to our admin and I tried the following cURL command via the shell of the server (rszh.txt attached):
curl -X POST -d @rszh.txt https://www.geoseaportal.de/soapServices/CSWStartup? --header "Content-Type:text/xml"
The response are all the records of the CSW. If I request the CSW using RESTClient (Firefox Addon) I get the same response. Here are the stats:
URL: https://www.geoseaportal.de/soapServices/CSWStartup?
“POST” request:
<GetRecords
xmlns="http://www.opengis.net/cat/csw/2.0.2"
service="CSW" version="2.0.2"
outputFormat="application/xml"
outputSchema="http://www.isotc211.org/2005/gmd"
xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0"
xmlns:ows="http://www.opengis.net/ows"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:dct="http://purl.org/dc/terms/"
xmlns:gml="http://www.opengis.net/gml"
resultType="results"
startPosition="1"
maxRecords="5">
<Query typeNames="gmd:MD_Metadata">
<ElementSetName typeNames="">brief</ElementSetName>
<Constraint version="1.1.0">
<ogc:Filter>
<ogc:PropertyIsLike escapeChar="\" singleChar="?" wildCard="*">
<ogc:PropertyName>apiso:anytext</ogc:PropertyName>
<ogc:Literal>Strömung</ogc:Literal>
</ogc:PropertyIsLike>
</ogc:Filter>
</Constraint>
</Query>
</GetRecords>
And now to the error messages of the two different GN versions installed on the server:
GN 2.10.3
/with "Catalogue Services for the Web ISO profile 2.0" Harvesting/
"Error: Raised exception when searching: Error on line 1: White spaces are required between publicId and systemId.
Class: OperationAbortedEx
Stack:
at: org.fao.geonet.kernel.harvest.harvester.csw.Harvester file: Harvester.java line: 508 method: doSearch
at: org.fao.geonet.kernel.harvest.harvester.csw.Harvester file: Harvester.java line: 231 method: search
at: org.fao.geonet.kernel.harvest.harvester.csw.Harvester file: Harvester.java line: 103 method: harvest
at: org.fao.geonet.kernel.harvest.harvester.csw.CswHarvester file: CswHarvester.java line: 244 method: doHarvest
at: org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor file: AbstractHarvester.java line: 400 method: process
at: org.fao.geonet.kernel.harvest.harvester.AbstractHarvester file: AbstractHarvester.java line: 470 method: harvest
at: org.fao.geonet.kernel.harvest.harvester.HarvesterJob file: HarvesterJob.java line: 29 method: execute
at: org.quartz.core.JobRunShell file: JobRunShell.java line: 213 method: run
at: org.quartz.simpl.SimpleThreadPool$WorkerThread file: SimpleThreadPool.java line: 557 method: run"
/with "OGC Web services (ie WMS, WFS, etc.)" Harvesting/
no error message, just one records returned (metadata about the the CSW itself)
GN 3.0.0RC0
"2015-04-16 09:50:31,682 WARN [GSP_1] - Raised exception when searching : org.fao.geonet.csw.common.exceptions.InvalidParameterValueEx: code=InvalidParameterValue, locator=null, message=bad service type: null
2015-04-16 09:50:31,757 WARN [GSP_1] - Raised exception when searching : org.fao.geonet.csw.common.exceptions.InvalidParameterValueEx: code=InvalidParameterValue, locator=null, message=bad service type: null
2015-04-16 09:50:31,757 ERROR [GSP_1] - Unknown error trying to harvest
2015-04-16 09:50:31,757 ERROR [GSP_1] - Raised exception when searching: bad service type: null
2015-04-16 09:50:31,758 ERROR [GSP_1] - Raised exception when searching: bad service type: null
OperationAbortedEx : Raised exception when searching: bad service type: null
at org.fao.geonet.kernel.harvest.harvester.csw.Harvester.doSearch(Harvester.java:553)
at org.fao.geonet.kernel.harvest.harvester.csw.Harvester.search(Harvester.java:251)
at org.fao.geonet.kernel.harvest.harvester.csw.Harvester.harvest(Harvester.java:110)
at org.fao.geonet.kernel.harvest.harvester.csw.CswHarvester.doHarvest(CswHarvester.java:174)
at org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor.process(AbstractHarvester.java:494)
at org.fao.geonet.kernel.harvest.harvester.AbstractHarvester.harvest(AbstractHarvester.java:563)
at org.fao.geonet.kernel.harvest.harvester.HarvesterJob.execute(HarvesterJob.java:31)
at org.quartz.core.JobRunShell.run(JobRunShell.java:213)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557)
Caused by: org.fao.geonet.csw.common.exceptions.InvalidParameterValueEx: code=InvalidParameterValue, locator=null, message=bad service type: null
at org.fao.geonet.csw.common.exceptions.CatalogException.createException(CatalogException.java:173)
at org.fao.geonet.csw.common.exceptions.CatalogException.unmarshal(CatalogException.java:146)
at org.fao.geonet.csw.common.requests.CatalogRequest.execute(CatalogRequest.java:151)
at org.fao.geonet.kernel.harvest.harvester.csw.Harvester.doSearch(Harvester.java:541)
... 8 more
2015-04-16 09:50:31,778 WARN [GSP_1] - Raised exception while harvesting from : GSP_1 (CswHarvester)
2015-04-16 09:50:31,778 WARN [GSP_1] - (C) Class : ArrayIndexOutOfBoundsException
2015-04-16 09:50:31,778 WARN [GSP_1] - (C) Message : 1"
I'm totally lost on this issue so I'd be so glad about any help. Thanks in advance
Christian
(attachments)
rszh.txt (966 Bytes)
