Hi!
I used the CSW test client to successfully search and return metadata using the GetRecords function. However, I noticed records were being returned with dublin core tags/format even for metadata that were not DC. Is there a way to alter the output format from CSW? Or have it use a custom made style sheet to output user defined formats? Thanks!
Shawn
