I am using Geospatial Portal 2018 and GeoNetwork Metadata Catalogue. I want
to use Search for data (metadata) function from portal to make search for
metadata from my GeoNetwork.
I have registered CSW from Geonetwork in Geospatial Portal instance, but any
search returns no results. I have enabled DEBUG logging in Portal's
web.config and according to log file Metadata search is forbidden. Debug
file is uploaded. CSWdebugFile.txt
<http://osgeo-org.1560.x6.nabble.com/file/t384860/CSWdebugFile.txt>
Do i need to make change in settings section in GeoNetwork?
Best regards,
Nenad.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi nenad,
On Mon, Apr 29, 2019 at 5:05 PM nenad <nenadsbc@anonymised.com> wrote:
any
you don't need to do any change in GeoNetwork. CSW endpoint is enabled by
default. Just check that you are querying the right URL.
Usually the CSW endpoint is at http://example.com:port
/geonetwork/srv/eng/csw
Juan Luis.
*Vriendelijke groeten / Kind regards,Juan Luis RodrÃguez.
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
