Dear all,
I extended the ISO codelist to add extra keyword types other than
theme, place, discipline, temporal and stratum. The codelist URL is
then different from the standard
http://www.isotc211.org/2005/resources/codeList.xml.
I have two related questions :
1) Can I change some template file to replace the standard codelist
URL with the new one ?
2) Would it be possible to add a new thesaurus rdf file to the new types ?
The purpose is to edit from geonetwork with a result which would be
compliant with a custom codelist.
Any help would be greatly appreciated.
Ramzi OUESLATI
Hi Ramzi,
We have also extended some of the code lists as well as created our own. For example, we have extended the MD_ScopeCode list (See http://asdd.ga.gov.au/asdd/profileinfo/GAScopeCodeList.xml).
We reference this code list in the metadata as follows:
<gmd:hierarchyLevel>
<gmd:MD_ScopeCode codeList="http://asdd.ga.gov.au/asdd/profileinfo/GAScopeCodeList.xml#MD_ScopeCode" codeListValue="activity"/>
</gmd:hierarchyLevel>
You could do something similar eg.
<gmd:type>
<gmd:MD_KeywordTypeCode codeList="http://asdd.ga.gov.au/asdd/profileinfo/gmxCodelists.xml#MD_KeywordTypeCode" codeListValue="bob"/>
</gmd:type>
Where 'bob' is your new MD_KeywordTypeCode and the URL points to your extended copy of the gmxCodelists.xml file.
Having said that, I don't know how to get GeoNetwork to point to a customised codeList. Can anyone else helps with that part?
I hope that this helps.
John
-----Original Message-----
From: Ramzi Oueslati [mailto:geonetwork-users@anonymised.com]
Sent: Friday, 12 August 2011 6:33 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] custom codelist
Dear all,
the new types ?
Ramzi OUESLATI
Get a FREE DOWNLOAD! and learn more about uberSVN rich system,
user administration capabilities and model configuration. Take
the hassle out of deploying and managing Subversion and the
tools developers use with it.
http://p.sf.net/sfu/wandisco-dev2dev
GeoNetwork-users mailing list
I need this as well. Is there anyone who has a suggestion on how to add new
descriptive keyword types to the UI?
Do the values used for the code list ever get validated against the url
associated with the keyword?
I'm a developer, but not that familiar with GeoNetwork or the standards -
any help would really be appreciated.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/custom-codelist-tp6679633p6704698.html
We have developed an ISO 19139 CT_CodelistCatalogue for keywords used in Australia and New Zealand. The code list is available at URL:
http://asdd.ga.gov.au/asdd/profileinfo/anzlic-theme.xml
We use Schematron to verify that the content of the keyword code is in the keyword codeList. The Schematron is available at URL:
http://asdd.ga.gov.au/asdd/profileinfo/codeListValidation.sch
An example of how we use this keyword code list follows:
<gmd:descriptiveKeywords>
- <gmd:MD_Keywords>
- <gmd:keyword>
<gco:CharacterString>MARINE</gco:CharacterString>
</gmd:keyword>
- <gmd:keyword>
<gco:CharacterString>MARINE-Coasts</gco:CharacterString>
</gmd:keyword>
- <gmd:keyword>
<gco:CharacterString>OCEANOGRAPHY-Physical</gco:CharacterString>
</gmd:keyword>
- <gmd:type>
<gmd:MD_KeywordTypeCode codeList="http://asdd.ga.gov.au/asdd/profileinfo/gmxCodelists.xml#MD_KeywordTypeCode" codeListValue="theme">theme</gmd:MD_KeywordTypeCode>
</gmd:type>
- <gmd:thesaurusName>
- <gmd:CI_Citation>
- <gmd:title>
<gco:CharacterString>ANZLIC Search Words</gco:CharacterString>
</gmd:title>
- <gmd:date>
- <gmd:CI_Date>
- <gmd:date>
<gco:Date>2008-05-16</gco:Date>
</gmd:date>
- <gmd:dateType>
<gmd:CI_DateTypeCode codeList="http://asdd.ga.gov.au/asdd/profileinfo/gmxCodelists.xml#CI_DateTypeCode" codeListValue="revision">revision</gmd:CI_DateTypeCode>
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
- <gmd:edition>
<gco:CharacterString>Version 2.1</gco:CharacterString>
</gmd:edition>
- <gmd:editionDate>
</gmd:editionDate>
- <gmd:identifier>
- <gmd:MD_Identifier>
- <gmd:code>
<gco:CharacterString>http://asdd.ga.gov.au/asdd/profileinfo/anzlic-theme.xml#anzlic-theme</gco:CharacterString>
</gmd:code>
</gmd:MD_Identifier>
</gmd:identifier>
- <gmd:citedResponsibleParty>
- <gmd:CI_ResponsibleParty>
- <gmd:organisationName>
<gco:CharacterString>ANZLIC the Spatial Information Council</gco:CharacterString>
</gmd:organisationName>
- <gmd:role>
<gmd:CI_RoleCode codeList="http://asdd.ga.gov.au/asdd/profileinfo/gmxCodelists.xml#CI_RoleCode" codeListValue="custodian">custodian</gmd:CI_RoleCode>
</gmd:role>
</gmd:CI_ResponsibleParty>
</gmd:citedResponsibleParty>
</gmd:CI_Citation>
</gmd:thesaurusName>
</gmd:MD_Keywords>
</gmd:descriptiveKeywords>
- <gmd:descriptiveKeywords>
John
From: doubl-ee-verman [mailto:eeverman@anonymised.com]
Sent: Saturday, 20 August 2011 5:42 AM
Subject: Re: [GeoNetwork-users] custom codelist
how to add new
against the url
standards -
33p6704698.html
tools developers use with it. http://p.sf.net/sfu/wandisco-d2d-2
Hi John,
Thank you for your help.
We already do that.actually. I was wondering if GeoNetwork was able to
take that custom codelist URL into consideration so that I could
associate one thesaurus to one extended codelist. It seems this
requires some extra code.
Ramzi
2011/8/15 <john.hockaday@anonymised.com>:
Hi Ramzi,
<gmd:type>
</gmd:type>
John
Dear all,
the new types ?
Ramzi OUESLATI
