I wonder if anyone has attempted to create a new Metadata profile in
GeoNetwork. Well, you may ask whats the need.
In one of the departments here in Philippines, they are using a metadata
standard of their own definition with 140 elements. Within the metadata,
they have feature/attribute codes defined by another standard.
Well, now can we create our own Metadata profile and called it ABCD.
While doing this what templates that we need to change ? DB modification
(prefer to have one on PostGIS), Where to create the XML profile etc... well
you can call me bit (totally !!) confused.
Can someone please just give some advice and guidance on this? If possible
point me to the right resources if available.
Von: Richard Sanders <tiruchirapalli@anonymised.com>
An: geonetwork-users@lists.sourceforge.net
Gesendet: Freitag, den 4. Dezember 2009, 12:43:17 Uhr
Betreff: [GeoNetwork-users] Custom Metadata Profile
HI,
God Bless
Richard
Join us December 9, 2009 for the Red Hat Virtual Experience,
a free event focused on virtualization and cloud computing.
Attend in-depth sessions from your desk. Your couch. Anywhere. http://p.sf.net/sfu/redhat-sfdev2dev
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
__________________________________________________
Do You Yahoo!?
Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden Schutz gegen Massenmails. http://mail.yahoo.com
If the Philippine example is a Profile of ISO 19115, then the management is simple, although it sounds like it is not a Profile but a local 'standard' or schema in its own right. (Profile tends to be understood in the standards community as a subset or extension of an adopted standard).
What I would recommend is that you evaluate and map the elements from the local (XML) format into ISO and then construct an XSLT to transform the data into ISO 19115/19139 for saving and presenting. If you do this, then all the capabilities on ISO metadata are supported for query and presentation, otherwise you will have to write all your own. The other benefit is that you would promote the uptake of the international standard.
You could then add a transformation option in the batch import or Harvest Management options to transform the local metadata when it is committed to GeoNetwork.
Doug.
HI,
God Bless
Richard
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat T:703 648 4151 F:703 648-5755 C:703 459-5860
You have pointed me to the right resources. Let me get deep into that
subject to understand more. It will take a while for me to work this and
make it a success.
Thanks
Richard
On Sat, Dec 5, 2009 at 12:15 AM, Doug Nebert <ddnebert@anonymised.com> wrote:
GeoNetwork.
Doug.
HI,
well
God Bless
Richard
Douglas D. Nebert
