[GeoNetwork-users] Custom Schema Plugin - using a schematron
I'm using a discovery metadata standard which validates against a schematron:
http://www.mba.ac.uk/demonstrations/schematron/Validate.asmx?WSDL
If I want to use Geonetwork to manage and validate metadata compliant with this standard, how can I create a custom schema in GeoNetwork that validates against a schematron, I appear to need to use an XSD file.
Does GeoNetwork support the use of a Schematron for Custom Schemas?
Thanks
Dan
