Hello all,
we are using geonetwork 2.6.1 and i would like customise the geontwrok
interface.
How can i change the place of the layer tree (toctree) , print, legend
panel to put them on the right (east) of the map instead of the left
place (west).
Toctree is defined in ol_map.js in the object accordion. When i change
the region to east of the viewport object , nothing change
The javascript files used in GeoNetwork are the minified versions located in
web\geonetwork\scripts\lib.
To get your change working, you need download GeoNetwork source code, modify
the file web\src\main\webapp\scripts\ol_map.js and rebuild the minified
javascript files executing mvn install in the web folder.
The minified files are located in the folder
web\src\main\webapp\scripts\lib. Copy them to the folder
web\geonetwork\scripts\lib in your GeoNetwork installation and the change
you did in ol_map.js file should be available.
Jose García
On Thu, Dec 9, 2010 at 8:49 PM, silst <stephane.lii@anonymised.com>wrote:
Hello all,
interface.
place (west).
On jeu., 2010-12-09 at 21:25 +0100, jose garcia wrote:
Hi
located in web\geonetwork\scripts\lib.
modify the file web\src\main\webapp\scripts\ol_map.js and rebuild the
minified javascript files executing mvn install in the web folder.
The minified files are located in the folder web\src\main\webapp
\scripts\lib. Copy them to the folder web\geonetwork\scripts\lib in
your GeoNetwork installation and the change you did in ol_map.js file
Jose García
<stephane.lii@anonymised.com> wrote:
Hello all,
geontwrok
interface.
print, legend
the left
place (west).
i change
hello everybody,
One more question,
is it possible to put a WMS layer in the map display when editing a
metadata ?
Like the ol_minimap and the map defined in config_gui.xml ?
there is tags in config-gui.xml :
<metadata>
<width>100%</width>
<height>300px</height>
</metadata>
Can we put tags inside as :
<layers>
<layer server="http://www.tefenua.gov.pf/geowebcache/service/wms"
tocName="Fond" params="{layers: 'FondCached', format: 'image/jpeg'}"
options="{isBaseLayer: true}" />
</layers>
