I would like to customize the geonetwork v3.0.0, as I had already done for
the version 2.10.4
but it's hard without documentation.
I would like some information to:
- Change the default language. For doing this, I changed the field
<language></language> in several files, without any result.
- Add a new tab near the Map Tab.
- Add a banner above tabs (Where do I change the CSS ?)
- Where is configured the geoserver ? (It was configured before in
WEB-INF/geoserver-nodes.xml)
- Center the map on one region (I changed it in config-viewer.xml and
delete override -> no result)
Does anyone have information on one or more points of this list ?
Thanks in advance,
Regards.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Customization-of-geonetworkv3-0-0-tp5209924.html
All the ui code is there :
https://github.com/geonetwork/core-geonetwork/tree/develop/web-ui/src/main/resources/catalog
The default view code is in
https://github.com/geonetwork/core-geonetwork/tree/develop/web-ui/src/main/resources/catalog/views/default
You can find there the templates html files, and the javascript components.
Try to set gnGlobalSettings.locale.lang in some module
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/templates/top-toolbar.html#L31
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/views/default/templates/index.html#L15
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/views/default/less/gn_search_default.less
or with a OWS context
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/views/default/config.js#L15
On Tue, Jun 9, 2015 at 11:17 AM, onar123 <onaris123@anonymised.com> wrote:
the version 2.10.4
Thanks in advance,
Regards.
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
Thank you for your answers.
I managed to add a new tab, to add a banner and focus my map on my area,
with your help. For authorized zoom level, I modified this file
(/views/default/config.js). Do you know, if there is a better method, I
don't like change the java code.
But I cannot change the default language, I even changed the language
information in database without success. Do you have another suggestion?
Regards.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Customization-of-geonetworkv3-0-0-tp5209924p5210591.html
What do you mean, it's javascript code, not java. It is the config place,
so it's here you can customize your maps.
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/js/GnLocale.js#L50
It's either gnGlobalSettings.locale.lang if set (you can set in your config
module for example) or it's gotten from the url.
Have you tried a different url ? The srv/*eng*/ ? eng can be changed to
another language.
Whatever, if you want to have eng in your url but have a different language
in your app, you may set another value in gnGlobalSettings.lang
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/js/GnLocale.js#L52
Regards.
Florent Gravin
0479444492
