[GeoNetwork-users] Customize defaule metadata view
Hi list,
I have GeoNetwork (v 3.0.4) installed and I want to add the Supplemental
Information attributes to the default metadata view. That is, when i look
at the
geonetwork/srv/por/catalog.search#/metadata/01f90c54-1de6-4a87-8567-0fec94ebdb94
address, it will show the basic info (abstract, author, links) and also
Supplemental Information.
How can it be done? I'm a newbie in both Geonetwork AND web programing but
have a good understanding of linux
Thanks
Daniel
Hi Daniel
The basic view in the metadata detail page is managed an AngularJs with
this template:
https://github.com/geonetwork/core-geonetwork/blob/3.0.x/web-ui/src/main/resources/catalog/views/default/templates/recordView.html,
to display additional items you need to make sure that are available in
mdView.current.record.
Jose García
On Tue, Jul 19, 2016 at 8:23 PM, Daniel Victoria <daniel.victoria@anonymised.com>
wrote:
Hi list,
at the
Thanks
Daniel
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning
reports.http://sdm.link/zohodev2dev
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Hi Jose,
Thanks for the tip. I saw that
<https://github.com/geonetwork/core-geonetwork/blob/3.0.x/web-ui/src/main/resources/catalog/views/default/templates/recordView.html&gt;
is what makes up the Default metadata page. But where do I control what is
available in mdView.current.record?
Thanks
Daniel
On Wed, Jul 20, 2016 at 3:28 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Daniel
this template:
Jose García
daniel.victoria@anonymised.com> wrote:
Hi list,
at the
Thanks
Daniel
traffic
are
planning
I can give you one example.
You need to change config-lucene.xml
and maybe also iso19139/index-fields/default.xml
and finally recordView.html
View this message in context: http://osgeo-org.1560.x6.nabble.com/Customize-defaule-metadata-view-tp5277170p5278000.html
Hi Jose and all,
I think I'm halfway there.
Following Jose's tip and this post from amacar [1] I was able to place the
supplementalInformation in the default metadata view.
These are the steps I've done:
a) add Supplemental Information in config-lucene.xml, in the dumpFields
<field name="supplementalInformation" tagName="supplementalInformation"/>
b) add Supplemental Information in
schema_plugins\iso19139\index-fields\defauls.xsl
            <xsl:for-each
select="gmd:supplementalInformation/gco:CharacterString">
                <Field name="supplementalInformation" string="{string(.)}"
store="true" index="true"/>
            </xsl:for-each>
c) add Supplemental Information in default\tempaltes\recordView.html
    <div class="well"
         data-ng-bind-html="mdView.current.record.supplementalInformation |
newlines"
         data-title="Supplemental Information">
    </div>
With this I can see the supplemental Information text in a gray box,
similar to the abstract box and right bellow it. What I'd like to do now is
add a title before the supplemental information box. I tried using the
data-title but that did not work. I don't know much about html or css. How
can that be done?
Thanks
Daniel
[1] -
http://osgeo-org.1560.x6.nabble.com/Extend-Default-Metadata-View-td5262029.html
On Wed, Jul 20, 2016 at 9:03 AM, Daniel Victoria <daniel.victoria@anonymised.com>
wrote:
Hi Jose,
Thanks
Daniel
wrote:
Hi Daniel
this template:
Jose García
Hi list,
at the
but
Thanks
Daniel
traffic
are
planning
