I wondering is there a way to edit CSS styles for published metadata catalogue. What I want to do is to change elements colors, images, adjust layout a little bit etc.
Which files I have to edit to see changes? It doesn't seem changes done here C:\Tomcat\webapps\geonetwork\catalog\views\default\less affects the application.
Did you figure out what files you needed to change? I'm also trying to
figure out which ones to edit, I've tried Geonetwork.css and home.html as
well as the .less files to no avail.
Thanks
Kevin
It's a less file that wro4j processes to create the related css.
Changes should be taken automatically (but maybe not in production mode).
You can clear the wro4j cache from
http:/SERVERgeonetwork/srv/eng/admin.console#/tools with the option *Clear
JS & CSS cache*.
Jose García
On Wed, Jul 19, 2017 at 11:58 PM, Durkee <kevin_durkee@anonymised.com> wrote:
Hi Andzej
Thanks
Kevin
View this message in context: http://osgeo-org.1560.x6.
nabble.com/Customize-GeoNetwork-CSS-styles-tp5324153p5328476.html
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
