[GeoNetwork-users] Customize the footer
Hello,
I had installed the new Version 3.6.0.0. Before i used the version 3.2.2.0.
In the older version I had changed the footer of the geonetwork. I the new
version I also tried to change the footer but nothing happend. There are
still the same information. I found a footer file in
geonetwork\catalog\templates and in
geonetwork\catalog\views\default\templates.
Is there another file which I have to change to see my customize footer?
I would give me great pleasure if someone can give me a hint.
Tanja
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi, when you have your changes made in /catalog folder, then you can test
directly with
http://localhost:8080/geonetwork/srv/eng/catalog.search*?debug*
or go in the Admin console > tools > Clear JS/CSS cache.
HTH
Francois
Le jeu. 14 mars 2019 à 08:12, Tanja <tanja.ruecker@anonymised.com> a
écrit :
Hello,
Tanja
Sent from:
GeoNetwork-users mailing list
Thanks a lot. That solved my problem.
Tanja
Von: Francois Prunayre <fx.prunayre@...54...>
Gesendet: Donnerstag, 14. März 2019 09:24
An: Rücker, Tanja (18.51.5) <Tanja.Ruecker@...1636...>
Cc: Geonetwork-Users@...638...
Betreff: Re: [GeoNetwork-users] Customize the footer
Hi, when you have your changes made in /catalog folder, then you can test directly with
http://localhost:8080/geonetwork/srv/eng/catalog.search?debug
HTH
Francois
Le jeu. 14 mars 2019 à 08:12, Tanja <tanja.ruecker@...1636...<mailto:tanja.ruecker@…1636…>> a écrit :
Hello,
Tanja
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
