Thanks for that Florent. I can confirm that attempting to load the default map from the map panel fails (Bing remains). In Chrome debug tools console the stack trace:
TypeError: Cannot read property 'a' of null
at se (lib.js:809)
at te (lib.js:809)
at Object.ek [as transformExtent] (lib.js:810)
at k.service.loadContext (gn_search_default.js:463)
at gn_search_default.js:465
at lib.js:417
at lib.js:448
at k.$get.k.$eval (lib.js:462)
at k.$get.k.$digest (lib.js:459)
at k.$get.k.$apply (lib.js:462)(anonymous function) @ lib.js:438$get @ lib.js:413(anonymous function) @ lib.js:448$get.k.$eval @ lib.js:462$get.k.$digest @ lib.js:459$get.k.$apply @ lib.js:462m @ lib.js:418N @ lib.js:422w.onload @ lib.js:423
appears. Given lib.js is a large minified JS file it isn't very informative. I imagine that means it's either failing to find my context file, or there is an error in the XML/the XML is incomplete in some way?
Thanks again,
David.
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
