[GeoNetwork-users] DATE RANGE AND CSW
hI!!
I' would like know if the CSW standar let doing range date search.
I want search metadatas from a init date to a end date. Can I do this
search with CSW?
Any example??
Thank!!
Regards
-----Original Message-----
Sent: Thursday, January 24, 2013 06:12
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] DATE RANGE AND CSW
hI!!
search with CSW?
Any example??
What do you mean by init date? If you have an exact date range:
<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot; service="CSW" version="2.0.2"
resultType="results" startPosition="1" maxRecords="5"
outputFormat="application/xml"
outputSchema="http://www.opengis.net/cat/csw/2.0.2&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd&quot;&gt;
<csw:Query typeNames="csw:Record">
  <csw:ElementSetName>full</csw:ElementSetName>
  <csw:Constraint version="1.1.0">
     <ogc:Filter>
       <ogc:PropertyIsBetween>
         <ogc:PropertyName>dc:date</ogc:PropertyName>
         <ogc:LowerBoundary>
           <ogc:Literal>2010-10-10</ogc:Literal>
         </ogc:LowerBoundary>
         <ogc:UpperBoundary>
           <ogc:Literal>2011-10-10</ogc:Literal>
         </ogc:UpperBoundary>
       </ogc:PropertyIsBetween>
     </ogc:Filter>
   </csw:Constraint>
</csw:Query>
</csw:GetRecords>
If you want all records before a certain end date:
     <ogc:Filter>
       <ogc:PropertyIsLessThan>
       </ogc:PropertyIsLessThan >
     </ogc:Filter>
   </csw:Constraint>
</csw:Query>
</csw:GetRecords>
Note that both examples are untested (against GeoNetwork).
..Tom
Hi!!
I test this csw request against GeoNetwork 2.6.4:
    xmlns:gmd="http://www.isotc211.org/2005/gmd&quot; service="CSW"
version="2.0.2"
    outputSchema="csw:Record" resultType="results_with_summary"
    startPosition="1" maxRecords="500">
        <ElementSetName>summary</ElementSetName>
            <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;
                xmlns:gml="http://www.opengis.net/gml&quot;&gt;
                <ogc:And>
                        <ogc:PropertyName>changeDate</ogc:PropertyName>
                        <ogc:LowerBoundary>
                            <ogc:Literal>2013-01-27T12:58:47Z</ogc:Literal>
                        <ogc:UpperBoundary>
                            <ogc:Literal>2013-02-14T12:58:47Z</ogc:Literal>
                    <ogc:PropertyIsLike wildCard="%" singleChar="#"
                        escapeChar="!">
                        <ogc:PropertyName>title</ogc:PropertyName>
                        <ogc:Literal>%prueba%</ogc:Literal>
                    </ogc:PropertyIsLike>
                </ogc:And>
            </ogc:Filter>
        </csw:Constraint>
    </csw:Query>
</csw:GetRecords>
The response is correct. But I need search by createdate and dc:date not by
modify date. In this cases (createdate and dc:date) geonetwork 2.6.4
returns not correct results between specificated dates.
it is a bug of geonetwork?
Thank very much for your help.
2013/1/24 Kralidis,Tom [Ontario] <Tom.Kralidis@anonymised.com>
> From: ANT LOP [mailto:gwcvarekay@anonymised.com]
> hI!!
> search with CSW?
> Any example??
     <ogc:Filter>
         <ogc:LowerBoundary>
         <ogc:UpperBoundary>
     </ogc:Filter>
   </csw:Constraint>
</csw:Query>
</csw:GetRecords>
     <ogc:Filter>
     </ogc:Filter>
   </csw:Constraint>
</csw:Query>
</csw:GetRecords>
..Tom
Any help please?
It's possible search by dc:date (Dublin core) field in Geonetwork 2.6.4
with CSW standard?
Thank very much!!
2013/2/5 ANT LOP <gwcvarekay@anonymised.com>
Hi!!
version="2.0.2"
                <ogc:And>
                        <ogc:LowerBoundary>
                        <ogc:UpperBoundary>
                        escapeChar="!">
                </ogc:And>
            </ogc:Filter>
        </csw:Constraint>
    </csw:Query>
</csw:GetRecords>
by modify date. In this cases (createdate and dc:date) geonetwork 2.6.4
> hI!!
> search with CSW?
> Any example??
     <ogc:Filter>
         <ogc:LowerBoundary>
         <ogc:UpperBoundary>
     </ogc:Filter>
   </csw:Constraint>
</csw:Query>
</csw:GetRecords>
     <ogc:Filter>
     </ogc:Filter>
   </csw:Constraint>
</csw:Query>
</csw:GetRecords>
..Tom
Hi
All CSW queryables are defined in WEB-INF/config-csw.xml (here's the file
for 2.6.4:
https://github.com/geonetwork/core-geonetwork/blob/2.6.4/web/src/main/webapp/WEB-INF/config-csw.xml
For DC metadata, seem dc:date field is indexed as createDate Lucene field
(see
https://github.com/geonetwork/core-geonetwork/blob/2.6.4/web/src/main/webapp/xml/schemas/csw-record/index-fields.xsl),
that according to config-csw.xml corresponds to *CreationDate CSW queryable.
Jose García
On Mon, Feb 11, 2013 at 2:31 PM, ANT LOP <gwcvarekay@anonymised.com> wrote:
Any help please?
with CSW standard?
Thank very much!!
> Hi!!
> version="2.0.2"
> <ogc:And>
> <ogc:LowerBoundary>
> <ogc:UpperBoundary>
> escapeChar="!">
> </ogc:And>
> </ogc:Filter>
> </csw:Constraint>
> </csw:Query>
> </csw:GetRecords>
>> > hI!!
>> > search with CSW?
>> > Any example??
>> <ogc:Filter>
>> <ogc:LowerBoundary>
>> <ogc:UpperBoundary>
>> </ogc:Filter>
>> </csw:Constraint>
>> </csw:Query>
>> </csw:GetRecords>
>> <ogc:Filter>
>> </ogc:Filter>
>> </csw:Constraint>
>> </csw:Query>
>> </csw:GetRecords>
>> ..Tom
Free Next-Gen Firewall Hardware Offer
Buy your Sophos next-gen firewall before the end March 2013
and get the hardware for free! Learn more.
http://p.sf.net/sfu/sophos-d2d-feb
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
