Hi all, I've already posted this question on the geonetwork-devel list, but I have not received any answer, so I'm cross-posting here. If the admins feel this is inappropriate please let me know and feel free to delete this mail from the archives.
I'm having problems to debug a xsl file that renders html on the main page of Geonetwork.
I'm trying to use the commandline version of saxon whith the following command:
java -jar d:\apps\Tomcat_8.0.14\webapps\metadatos\WEB-INF\lib\saxon-9.1.0.8b-patch.jar -s:d:\amo\temp\input.xml -xsl:d:\apps\Tomcat_8.0.14\webapps\metadatos\xsl\main-page.xsl
This command returns the following error:
Warning: at xsl:stylesheet on line 4 column 45 of main-page.xsl:
Running an XSLT 1.0 stylesheet with an XSLT 2.0 processor
Error at xsl:include on line 10 column 69 of metadata-utils.xsl:
XTSE0165: java.io.FileNotFoundException:
d:\apps\Tomcat_8.0.14\webapps\metadatos\xsl\blanks\metadata-schema01\present\metadata.xsl
(El sistema no puede encontrar la ruta especificada)
Error at xsl:call-template on line 2083 column 45 of metadata.xsl:
XTSE0650: No template exists named showMap
Failed to compile stylesheet. 2 errors detected.
It seems I need a file /xsl/blanks/metadata-schema01/present/metadata.xsl that is not present in my installation (Geonetwork is running fine over Tomcat). I read in http://trac.osgeo.org/geonetwork/ticket/1034 that a new mechanism based in a XMLResolver class is used, but I don't know how to incorporate the resolver to my command.
Tanks in Advance
Alvaro Martin
Álvaro Martín Oliva
Nevintec Sistemas, S.L.
C/ Téllez, 30 - Oficina 2 - 2
28007 Madrid
Tlfno.: 91 221 10 60 / 91 221 09 10
http://www.nevintec.com
