I have a problem with deeply nested elements. I changed the iso19139 schema
according to my own needs. While nesting complex elements (type of
“CI_ResponsibleParty”) for example in an element called „dataQualityInfo” I
noticed a bug. The entire tree (sub-tree), with the mentioned
“dataQualityInfo” as the starting element, (while creating a new metadata
file, editing or doing simple preview) is displayed correctly with all
nested elements till the 15 level. Every element nested deeper (always above
the 15th level) is invisible. Those elements are built correctly, I have
checked. Are there any limits to nesting? How can I increase these limits or
get rid of them completely?
Łukasz
View this message in context: http://www.nabble.com/deeply-nested-elements-problem-tf4442266s18419.html#a12674543
Sent from the geonetwork-users mailing list archive at Nabble.com.
