[GeoNetwork-users] default map and adding wms
I am trying to customize the intermap viewer in GN and have some
troubles with the default maps and adding wms services at the same time.
As default maps in the mapviewer, I use some SRTM data (srtm_1) stored
in the embedded geoserver. I changed the mapContexts section in the
mapserver.xml to:
<mapContexts>
    <default name="Layers for default map -- DUMMY NAME:not used">
      <server url="http://localhost:8080/geoserver/wms&quot; type="2">
        <layer name="gn:srtm_1"></layer>
      </server>
        <layer name="gn:project_area_wgs84"></layer>
      </server>
    </default>
and this works fine for the default map, but I can't add any wms layers
because of the proxy settings at our office.
So, in order to enable adding wms services, I changed the proxy
configuartion of Intermap and added the proxy configuration in the file
intermap/WEB-INF/config.xml in the sections:
<general>
    <profiles>user-profiles.xml</profiles>
    <debug>false</debug>
    <uploadDir>WEB-INF/data/tmp</uploadDir>
    <maxUploadSize>50</maxUploadSize> <!-- Size must be in
megabyte (integer) -->
    <useProxy>true</useProxy>
    <proxyHost>myproxyHost</proxyHost>
    <proxyPort>8080</proxyPort>
  </general>
and further below again:
<appHandler class="org.wfp.vam.intermap.Intermap">
    <param name="mapServers" value="WEB-INF/mapServers.xml"
    <param name="axlRequests" value="WEB-INF/axl" />
    <!-- proxy server -->
    <param name="useProxy" value="true" />
    <param name="proxyHost" value="myproxyHost" />
    <param name="proxyPort" value="8080" />
After restarting Jetty, I can now add wms services, but the default maps
are gone. I guess that the conflict arises from the port number, but
don't know how to set up the port configuration correctly and what kind
of files I have to change.
Many thanks for any help in advance,
Heiko
