[GeoNetwork-users] default map extents
I'm looking for a way to have different initial map extents for the two
maps in the GN interface: the mini-search map and the larger display map.
Is that possible? I'm using the new search/display interface in GN 2.8
(latest nightly build) and the dimensions of the windows are different
enough that the initial coordinates of the map should be different. Thanks.
- John
Please help the DGS serve you better in the future by taking our user
survey!
http://www.dgs.udel.edu/news/please-take-our-user-survey
John Callahan
Research Scientist
Delaware Geological Survey
University of Delaware
john.callahan@anonymised.com
Hi John,
I think you will find that in WEB-INF/config-gui.xml (in v2.6.4 for sure, I haven't checked GIT/v2.8)
Look for
<mapSearch options="{projection: 'EPSG:4326', maxExtent: new OpenLayers.Bounds(-180,-90,180,90), units: 'degrees', restrictedExtent: new OpenLayers.Bounds(-180,-90,180,90)}">
and
<mapViewer options="{projection: 'EPSG:4326', maxExtent: new OpenLayers.Bounds(-180,-90,180,90), units: 'degrees', restrictedExtent: new OpenLayers.Bounds(-180,-90,180,90)}">
kind regards
Jørn-Vegard Røsnes
----- Original Message -----
Fra: "John Callahan" <john.callahan@anonymised.com>
Til: "Geonetwork Users" <geonetwork-users@lists.sourceforge.net>
Sendt: 19. oktober 2012 16:07:41
Emne: [GeoNetwork-users] default map extents
two
map.
GN 2.8
different
Thanks.
- John
survey!
John Callahan
Research Scientist
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
GeoNetwork-users mailing list
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
Thank you. I believe those settings affect the maps in the Gn 2.8 default
interface. It does not alter the extents in the maps in the /search and
/tabsearch interfaces, which are primarily javascript driven.
- John
John Callahan
Research Scientist
On Mon, Oct 22, 2012 at 2:47 AM, Jørn Vegard Røsnes <jorn@anonymised.com>wrote:
Hi John,
Look for
and
kind regards
Jørn-Vegard Røsnes
> two
> map.
> GN 2.8
> different
> Thanks.
> - John
> survey!
> John Callahan
> Research Scientist
CONFIDENTIALITY
meant
use is
in
properly.
