Can help me, I need to stablish spanish language by default on my Geonetwork
2.10.4
I tried:
On index.html
window.location="srv/en/main.home" + search; by
window.location="srv/es/main.home" + search;
On config.xml
<language>en</language> by <language>es</language>
But not work.
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Default-Spanish-language-Geonetwork-2-10-4-tp5170281.html
Hi
Related to 2.10.4 I would recommend to wait (for now has been removed from
Sourceforge to avoid confusion), as we're checking some bugs found in CSW
harvester.
Related to the UI, if you use the htm5ui (default UI) instead of classic
UI, you need to change this in the file config-overrides-html5ui-props.xml:
<widget.url>../../srv/eng/search</widget.url>
to
<widget.url>../../srv/spa/search</widget.url>
Jose GarcĂa
On Wed, Oct 29, 2014 at 10:48 PM, cbeltran <cbeltran@anonymised.com> wrote:
Geonetwork
2.10.4
I tried:
On index.html
On config.xml
But not work.
Thanks
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcĂaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
