Good Day to all
I have a question about my installation geonetwork 2.10.4. From one moment
to another in a metadata editing, the top menu button is appearing "minor
edit" had been working far is the first time you see it, how I can delete it
??? Since when clicking on it does not do anything, I need to remove it from
this menu and not let me see the other options out there.
<http://osgeo-org.1560.x6.nabble.com/file/n5225427/geodisabled.png>
Thanks...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Delete-Minor-Edit-tp5225427.html
Hi
The option is used in the metadata save, if the option is checked the
metadata change date is not updated. The change depends on the UI you're
using.
Jose García
On Tue, Sep 22, 2015 at 3:19 PM, cbeltran <cbeltran@anonymised.com> wrote:
Good Day to all
it
from
Thanks...
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>M: +31 (0)655 818332 <+31655818332>
<https://www.facebook.com/geocatbv> <https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
Thanks Jose
How to disabled this option???
Regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Delete-Minor-Edit-tp5225427p5225473.html
Hi
Adding the following line:
tbarConfig: {hideMinorEdit: true},
after this one removes that option:
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web-client/src/main/resources/apps/html5ui/js/App.js#L263
Note that you need to build again the html5ui application from the sources
to get the updated minified files.
Jose García
On Tue, Sep 22, 2015 at 6:49 PM, cbeltran <cbeltran@anonymised.com> wrote:
Thanks Jose
Regards
