Gents,
Well, I've just done it (I was going to need to do this soon anyway). There is no getting past the fact that the public context must be the same as the local context at present. This is how you change your local context to match whatever you want for your public one.
There are two addLifeCycle elements in jetty.xml. You will want to uncomment the one which is currently commented out, and comment out the one which isn't. Make sure you take care of the comment lines inside the section you need to comment out.
You will need to create a contexts directory in the jetty directory.
Populate the addLifeCycle xml element and the contexts/geonetwork.xml file by following (VERY CAREFULLY!) the instructions on this page: http://docs.codehaus.org/display/JETTY/ContextDeployer
Worked example.
I have two branded geonetwork installs (based on 2.6.0 and 2.6.1) running on localhost 8080 and 8081, which I want to be visible at /261/ukmetadataeditor and /260/ukmetadataeditor:
My geonetwork.xml in my geonetwork.2.6.1 install is as follows. There is a very similar(!) one in my 2.6.0 install:
<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE Configure PUBLIC "-//Mort Bay Consulting//DTD Configure//EN" "http://jetty.mortbay.org/configure.dtd">
<Configure class="org.mortbay.jetty.webapp.WebAppContext">
<Set name="contextPath">/261/ukmetadataeditor</Set>
<Set name="war"><SystemProperty name="jetty.home" default="."/>/../web/geonetwork/</Set>
</Configure>
In Apache's ProxyPass and ProxyPassReverse settings, make your localhost context the same as your public context.
ProxyPass /261/ukmetadataeditor http://localhost:8080/261/ukmetadataeditor
ProxyPassReverse /261/ukmetadataeditor http://localhost:8080/261/ukmetadataeditor
ProxyPass /260/ukmetadataeditor http://localhost:8081/260/ukmetadataeditor
ProxyPassReverse /260/ukmetadataeditor http://localhost:8081/260/ukmetadataeditor
I have added -Djetty.port=8080 (or 8081 for the other one) to the java line in bin/start-geonetwork.sh
I now start both processes with their respective bin/start-geonetwork.sh files, count to ten and restart httpd.
If it doesn't all work, then read the jetty/logs/output.log and apache log for clues
Justin.
PS You will need to do the same for geoserver - I haven't done that yet - an exercise for the reader
PPS Jose - Is it worth adding this, in brief, to the install guide? If so, I'll write it up a little better, removing references to ukmetadataeditor.
-----Original Message-----
Sent: 23 November 2010 16:28
To: Armin Retterath
Cc: geonetwork-users@lists.sourceforge.net; geonetwork-devel@anonymised.comrge.net
Subject: Re: [GeoNetwork-devel] [GeoNetwork-users] Deploying at non-root webaddress
Thanks for your responses Timo and Armin. Unless I am misunderstanding the functionality of mod_proxy, I don't think that would solve my problem. The web address www.example.gov:80/glri/geonetwork already correctly maps to www.example.gov:8080/geonetwork, and accessing www.example.gov:80/glri/geonetwork loads the main.home page, but main.home tries loading almost all of its resources from www.example.gov:80/geonetwork (without the glri directory). www.example.gov:80/geonetwork isn't mapped to anything (and shouldn't be), so those resource requests fail. It seems like GeoNetwork is assuming that it will always be located at the root of a domain. I was hoping that there would be some configuration option that would make GN request resources from www.example.gov:80/glri/geonetwork.
Ryan
On Nov 23, 2010, at 12:06 AM, Armin Retterath wrote:
hello together,
a simple solution maybe following proxy rule for apache2:
<IfModule mod_proxy.c>
ProxyPreserveHost on
ProxyPass /geonetwork http://127.0.0.1:8180/geonetwork
ProxyPassReverse /geonetwork http://127.0.0.1:8180/geonetwork
ProxyPass /geoserver http://127.0.0.1:8180/geoserver
ProxyPassReverse /geoserver http://127.0.0.1:8180/geoserver
</IfModule>
store it in the conf.d directory and activate mod_proxy for apache2.
regards
armin
Am Montag 22 November 2010, um 00:44:00 schrieb Timo Proescholdt:
Hi Ryan,
Le 19.11.2010 21:14, Ryan Zoerb a écrit :
I'm trying to deploy GeoNetwork 2.6.0 at ####.####.gov/glri/geonetwork,
but haven't figured out how to do so. The url is mapped to GeoNetwork,
but when I access that page, most of the resources GN tries loading from
.gov/geonetwork, so the srv/en/main.home page loads, but is broken. Is
there a configuration option that I need to change?
if you use Tomcat & Apache you can use mod_jk to map requests to the
apache (on port 80) to applications running in tomcat (on port 8080).
e.g example.org:80/mypage/geonetwork -> example.org:8080/geonetwork
There are numerous examples out there on how to connect tomact & apache
with mod_jk (or mod_proxy) in the internet.
best
Timo
Ryan
--- Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
GeoNetwork-users mailing list
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
Increase Visibility of Your 3D Game App & Earn a Chance To Win $500!
Tap into the largest installed PC base & get more eyes on your game by
optimizing for Intel(R) Graphics Technology. Get started today with the
Intel(R) Software Partner Program. Five $500 cash prizes are up for grabs.
http://p.sf.net/sfu/intelisp-dev2dev
GeoNetwork-devel mailing list
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
