[GeoNetwork-users] Difficulty implementing GN4.0.3
You have provided more good suggestions. When I use {website}/geonetwork/srv/eng/catalog.search?debug, the splash pages and GN generally is visible and usable, albeit slowly. Four main errors are indicated in the console log:
    1.Some cookies are misusing the recommended “SameSite“ attribute 3
    2.This page uses the non standard property “zoom”. Consider using
    calc() in the relevant property values, or using “transform” along
    with “transform-origin: 0 0”._catalog.search
    <https://soggy2.zoology.ubc.ca/geonetwork/srv/eng/catalog.search&gt;\_
    3.Using //@ to indicate sourceMappingURL pragmas is deprecated.
    Use //# instead
    Uncaught Error: [$injector:modulerr]
    http://errors.angularjs.org/1.5.2/$injector/modulerr?p0=gn_s…Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A7%3A29892
    <http://errors.angularjs.org/1.5.2/$injector/modulerr?p0=gn_search_default&p1=[%24injector%3Anomod]%20http%3A%2F%2Ferrors.angularjs.org%2F1.5.2%2F%24injector%2Fnomod%3Fp0%3Dgn_search_default O%2F<%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A20%3A416 ge%2F<%2F<%2F<%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A39%3A147 b%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A38%3A211 ge%2F<%2F<%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A38%3A454 g%2F<%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A53%3A287 p%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A21%3A355 g%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A53%3A136 db%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A57%3A165 c%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A34%3A463 xc%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A35%3A274 be%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A34%3A83 %40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A322%3A123 i%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A7%3A27151 fireWith%40https%3A%2F%2Fsoggy2.zoology.ubc.ca%2Fgeonetwork%2Fstatic%2Flib.js%3Fv%3D353b4ad4b87d6d708a27c5dab93b70109db683d6%3A7%3A27914%252&gt;
    4.Source map error: Error: request failed with status 404
Errors 1 and 2 appear relatively benign to me. Error 4 (404 - page not found) seems curious, and could be some module I neglected to load, but the website does load when I append "?debug". The "Uncaught Error" hyperlink in Error 3 is consistent with the original '<' error pointing at a syntax error related to Angular JS:
    "This error occurs when a module fails to load due to some
    exception. The error message above should provide additional
    context. A common reason why the module fails to load is that
    you've forgotten to include the file with the defined module or
    that the file couldn't be loaded."
I am thinking maybe I should try to build GN from GitHub?
-- terry
On 2021-04-19 12:48 a.m., Florent Gravin wrote:
Indeed there seem to be an issue on the frontend side.
You can run the debug mode to check if the error is more releavant: geonetwork/srv/eng/catalog.search?debug
Hope it helps
On Mon, Apr 19, 2021 at 9:33 AM Terry <terry.curran@anonymised.com <mailto:terry.curran@anonymised.com>> wrote:
    Thank you. I had not thought to use the dev console- this is
an
    excellent suggestion. The resulting log seems to indicate a "<"
    somewhere in the angularjs module.
    How could I isolate this further?
    <!-- SNIP -- >
    On 2021-04-18 11:15 p.m., Jose Garcia wrote:
    > Hi Terry
    > Have you checked in the Chrome dev console if the request has
    any errors?
    > Regards,
    > Jose García
    > On Mon, Apr 19, 2021 at 4:14 AM Terry <terry.curran@anonymised.com
    > <mailto:terry.curran@anonymised.com>> wrote:
    > We run a reverse proxy and use Openjdk8 and Jetty9.4 on a RHEL8
    > server.
    > Jetty is working fine, and serving geoserver with no problems.
    > We implemented Elasticsearch as a daemon from
the RPM source.
    > Implementation checks with systemctl and with
curl
    > http://localhost:9200
    <http://localhost:9200>
    > show everything as expected. The ES config.properties in
    GN are as
    > expected. The external data folder gn_dir contains the
    complete
    > expected tree structure, with ES features, records,
    records_french
    > and
    > searchlogs. ES queries work.
    > A clean install of the postgres-postgis GN database yielded the
    > expected
    > tables structure with appropriate elements.
    > No errors are reported in the geonetwork log or in the
    jetty log.
    > The
    > Jetty log reports both geonetwork and geoserver as AVAILABLE.
    > However, when we attempt to access GN with a browser using
    > https://{website}/geonetwork, we get a header
response
    > https://{website}/geonetwork/srv/eng/catalog.search
    complete with the
    > standard earth-like logo, but with a completely blank
    screen. So it
    > seems like it is trying to work.
    > We have also tried the h2 database with exactly the same
    results. We
    > have opened port 8080 and tried http access, with the same
    result.
    > Any ideas as to what we are missing?
    > Vriendelijke groeten / Kind regards,
    > Jose García
    > <http://www.geocat.net/&gt;
    > Veenderweg 13
    > 6721 WD Bennekom
    > The Netherlands
    > T: +31 (0)318 416664 <tel:+31318416664>
    > Please consider the environment before printing this email.
    GeoNetwork-users mailing list
    <mailto:GeoNetwork-users@lists.sourceforge.net>
    <https://lists.sourceforge.net/lists/listinfo/geonetwork-users&gt;
    <http://sourceforge.net/projects/geonetwork&gt;
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
*Technical Leader - Architect*
+33 4 58 48 20 36
