hi
could help me, what's path or directory that stores Geonetwork shapefiles?
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Directory-Shapefile-tp5170287.html
Hi
When you upload a shapefile (as an online resource) to metadata, is stored
by default in the WEB-INF/data/data/metadata_data, you'll see that there
are some folders in this format:
00001-00099
00100-00199
In each there is a folder with metadata identifier and two subfolders:
private and public.
00001-00099
10
private
public
The shapefile (or other file that you added as an online resource) is
stored in the private folder, public folder is used to the thumbnails.
Jose GarcĂa
On Thu, Oct 30, 2014 at 12:13 AM, cbeltran <cbeltran@anonymised.com> wrote:
hi
Thanks
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcĂaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
